no oil pressure
pmrphil
norm
6t6mustang
Bart Knox
no oil pressure  Empty no oil pressure
Post  Bart Knox June 6th 2017, 9:20 pm
I finally got my motor in my truck and all hooked up. Started with the gauges today and didn't get a oil pressure reading so I pulled the sencor out from behind the intake and fired it up and no oil came out
.. Does this mean the pump isn't working???
Bart Knox
Bart Knox
http://W. B Knox&son LTD Huntsville Ontario
no oil pressure  Empty Re: no oil pressure
Post  6t6mustang June 6th 2017, 9:45 pm
It means oil isn't pumping, there could be a couple things to cause that.. oil pump driveshaft got installed right?
6t6mustang
6t6mustang
Post  Bart Knox June 7th 2017, 2:25 pm
Thats what it was. It was rammed off to the side into the camshaft gear. Don't know how buddy screwed that up
Bart Knox
Bart Knox
Post  dfree383 June 7th 2017, 2:56 pm
If you been running it without oil pressure you better be tearing it down for bearings and inspection.
Post  Bart Knox June 7th 2017, 3:35 pm
Maybe 5 minutes tops... What do you think
Bart Knox
Bart Knox
Post  dfree383 June 7th 2017, 4:23 pm
You better be pulling it down
Post  Bart Knox June 7th 2017, 4:58 pm
The guy thats is going to help me this weekend said we should pull the motor change bottom end bearings and polish the crankshaft
Bart Knox
Bart Knox
Post  norm June 7th 2017, 6:58 pm
And then prime it, i hope.
norm
norm
Post  pmrphil June 7th 2017, 7:14 pm
If that was a new cam, I'd plan on replacing that, too, along with the lifters. Five MINUTES ??
pmrphil
Post  Bart Knox June 7th 2017, 8:31 pm
Five minutes is probably over what it ran... I fired it up for probably 90 seconds when I got the muffler on and probably not even that long when I hooked up the gauges and buddy that built it fired it up on the floor at his shop just to check for oil pressure and said it had pressure but dont see how that is possible when the drive was not in the distributor or the hole the bottom of the distributor go's in.
Bart Knox
Bart Knox
Post  dfree383 June 7th 2017, 9:48 pm
A pan gasket is cheaper than a new engine
Post  Bart Knox June 7th 2017, 9:57 pm
Not sure what you mean? Got a new pan gasket going to take the pan off and inspect everything for starters and hope everything is alright and if it looks like it is than do the bearing anyway to be safe break it in and hope for the best I guess. I'll have to go with what the guy I have helping me says because he builds motors and he's the one looking at it
Bart Knox
Bart Knox
Post  DILLIGASDAVE June 8th 2017, 3:58 am
After 5 mins without oil slinging around inside the crankcase the piston skirts, piston rings, & cylinder walls might be toast too.
Post  D. Sea June 8th 2017, 8:13 am
Bart Knox wrote:Not sure what you mean? Got a new pan gasket going to take the pan off and inspect everything for starters and hope everything is alright and if it looks like it is than do the bearing anyway to be safe break it in and hope for the best I guess. I'll have to go with what the guy I have helping me says because he builds motors and he's the one looking at it
Not trying to sound condescending but if your buddy builds engines and made that kind of catastrophic mistake... Well... he wouldn't be touching the engine again IMO.
D. Sea
D. Sea
Post  pmrphil June 8th 2017, 8:19 am
And that same buddy is the one who claimed it showed oil pressure when it couldn't have? Do you really want to trust him again?
pmrphil
Post  Bart Knox June 8th 2017, 11:11 pm
No not the same guy is helping me know I'm done with him... He's not a buddy and the only thing he'll be doing is reimbursing me for what has to be replaced.
Bart Knox
Bart Knox
Post  4604X4 June 9th 2017, 10:00 am
How can the oil pump drive shaft not be installed right? How would you get the distributor in if the pump shaft was not installed properly (missing, I can understand).
I don't believe there is enough room in the block to have the shaft sitting cocked in the block (not seated in the oil pump or distributor) and still have room to install distributor.
4604X4
4604X4
Post  rmk57 June 9th 2017, 11:10 am
I had the oil pump shaft fall off once while installing it with the distributor. Didn't notice or hear it fall of the distributor. What I did notice was the loud "clank" when the crankshaft hit it when starting the engine up for the first time. It also put a nice outward crease in my oil pan.
rmk57
Post  pmrphil June 9th 2017, 12:44 pm
Hopefully you have learned since then that the shaft goes in with the PUMP, (from the bottom!) not with the distributor. And the clip goes on the distributor end. Shocked
pmrphil
Post  Bart Knox June 9th 2017, 11:44 pm
I tried taking a picture but cant get it to show up... Theres lots of room for the distributor to go in the dive is way pushed off just touching the side of the camshaft gear
Bart Knox
Bart Knox
