6/8-71 + Juice
6/8-71 + Juice
Hey guys anyone using a 6 or 8-71 Blower with either a plate type or fogger N2O system
I am debating Bigger Stroker N/A motor + "Juice" or Smaller 6-71 Blown motor + "Juice".
I think a 505 setup for E-85 (.040 over 429-460 + 4.15 crank) <with a 1:1 driven 6-71 that would yield 6.1 lbs of boost> would be more than a match for a N/A 557 (.080 over 429-460 + 4.5 inch crank).
Then add 100-250 HP of N2O at mid-track.
511Fox- Posts : 251
Re: 6/8-71 + Juice
I think big cubic inch motor with a big blower and nitrous.
Yes. a fogger and roots works and is prety common
whatbumper- Posts : 3024
blown/nitrous
It works well, most guys do it for the "intercooler" effect and only put a 50 shot to their blowers. Even at 505 cid I would opt for the 871, you can turn it slower and not create as much heat, and it leaves you with room to grow if you decide for more cubes later. Big nitrous and a blower will make huge power, and you will have the torque of a much larger engine. Good luck with that monster! Greg blown473 soon to be 514/521
blown473- Posts : 376
High CR+Lower Boost+N2O
I know I can't be the only one thinking this,6-9 Lbs of boost with a 9.2-10.2:1 CR + a 100-200 Fogger V.S. a 7-8.5:1 CR and 8-12 LBs of boost.
Last edited by 511Fox on April 6th 2010, 8:49 am; edited 1 time in total (Reason for editing : can't spell)
511Fox- Posts : 251
Re: 6/8-71 + Juice
I went to a turbo so I didn't have to lug those darn bottles around. So now I have two big a$$ ice coolers, what a trade off??
The intercooling effect as well as the added benefit or more power at the lower boost levels is pretty good IMO.
Intercoolers
They make a "Superchiller" Type Intercooler for Roots blowers.
I think a Water/Methanol setup plumbed into the Fogger would do better for the track and less boost for the street.
511Fox- Posts : 251
» Da pimp juice or dat juice in the 70's
» Now the plumbing begins
» How much juice can I put to it?
» 69 stang ....... on the juice !!!!
» Pimp Juice
» Pimp Juice
