Fuel pressure
Fuel pressure Empty Fuel pressure
Post  OldRedFord April 18th 2010, 10:18 pm
What should my fuel pressure be?
Engine is a mild 460 with a stock volume mechanical pump, Holley 750 cfm carb, Cam is
http://www.summitracing.com/parts/SUM-3500/
Should I install a fuel pressure regulator?
OldRedFord
OldRedFord
Fuel pressure Empty Re: Fuel pressure
Post  cool40 April 18th 2010, 10:34 pm
psi with a stock pump will probly be 5-6 psi depends on the pump and you should'nt need a regulator with it. Smile
