TFS A head
TFS A head
I know that this has been covered before but what can these heads do? Trick Flow A-460 – PN# TFS-21002, 5441B001, and 5451B001. What are there limits? I am beginning to get wishy washy on my ride. I figure out what I want to do. Dang choices.
whatbumper- Posts : 3024
Re: TFS A head
18-bolt deal will have you singing
the TFS-5441B001 is the standard bolt pattern each , bare casting
the TFS-5451B001 is the 18 bolt deal each, bare casting
and i believe that the 21002 # is an old casting deal
Last edited by bruno on April 25th 2010, 11:35 pm; edited 2 times in total (Reason for editing : added info)
Re: TFS A head
Limits of what?
Re: TFS A head
dfree383 wrote:Limits of what?
power baby, power. No really I read more of the rules. 4150 carb only, no SV1 Pro-Systems carbs or dAMBEST carbs, or 4150 throttle body or 90mm throttle body, mufflers required.
What kind of deck thickness do these bad boys have? On a race only high compressions combo what kind of power is capable on a motor up to 530" and 530-575" (100lb weight penalty)? I can run a single stage .078 nitrous pill too.
This is a local true street class. 275dr
Re: TFS A head
Well over 1,100 horsepower with that 575 ... I have seen over a 1,000 horsepower with a 528.
Re: TFS A head
That's what I wanted to here. Thanks.
Re: TFS A head
rmcomprandy wrote:Well over 1,100 horsepower with that 575 ... I have seen over a 1,000 horsepower with a 528.
windsor- Posts : 1167
Re: TFS A head
Isnt that more power than your making with your turbo on the SB?
Re: TFS A head
Maddmattmustangs wrote:rmcomprandy wrote:Well over 1,100 horsepower with that 575 ... I have seen over a 1,000 horsepower with a 528.
not even close the times he is running w/ the sb he is in the 1400 - 1600 range ...
Re: TFS A head
I am planning my personal car now which will not be quite as fast but hopefully cheaper to run/maintain.
My brother and I have the turbo car together and he runs the class above this one. That car is our primary focus. Our turbo motor made 675hp NA. We are running with an 88mm reducer in our 106mm turbo now so I would think that the 1600hp number Bruno threw out would be pretty fair. Later in the year we have a couple of races that we will pull the reducer so 2000hp+ is expected. We have also thought about selling/trading our other turbo (precision 101mm) for a true 94mm to run a couple SSO races in the NMRA.
on another note. Our problems the other day was confirmed to be a bad ignition box AND failing coil. We are planting cotton now so the next run will be this weekend. We keep missing races so run time is really low for us right now. We changed the ignition out and it runs much better now. Spools pretty quickly. I hope everything works because we have races on 7 out of the next 9 weekends.
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» P-51 Head's /Head Studs/pushrods (SOLD)
» P51 Head HP gain after head port
