Anyone running a 350 shot?
Barney
procharger 528
Jeremiah
Anyone running a 350 shot? Empty Anyone running a 350 shot?
Post  Jeremiah May 1st 2010, 2:05 pm
If so whats your tune up? how big is your motor? what kind of times you running? Im thinking of running 2 kits. one 250 on the hit and another 100 shot when the car settles... I have a built 466, C4 with brake. 3200lb mustang coupe...
Jeremiah
Anyone running a 350 shot? Empty Re: Anyone running a 350 shot?
Post  bruno May 1st 2010, 2:41 pm
not yet ... but will be testing soon
one thing you need to learn is "PATIENCE' with nitrous ........ 350 is a very large shot for the begginer , and im not saying you dont know but with the info you posted in requards to the tune you have on the plate , you gonna start poking holes in stuff Wink
i would say get your 1 stage lined out first , then work on the second kit .... that first stage @ a 250 shot should be setting your azz in the seat !!!! and you should be picking up some better #'s ( even though you have the p/c)
when i was spraying my plate before i met Steve i would pick up a couple of tenths ....but after i called him and got a baseline tune it was a completely different car ....hands down he knows his shit ...
just recently i sent both my plate and fogger back to him to get flowed and there was so much wrong with the parts , that i should she another hugh gain
there is a thread on here that you need to read i will bump it up for you
later Nick
http://WWW.CKRME.COM
Post  Jeremiah May 1st 2010, 5:15 pm
I am 100% taking baby steps with this car... I was just asking for later down the road after I get my first kit lined out.. Just seeing what everyone was running and what they were getting out of it... Very Happy
Jeremiah
Post  richter69 May 1st 2010, 6:53 pm
man thats a big hit for a plate, maybe when the new tfs intake comes out but with the victor I'd be careful.
Post  procharger 528 May 1st 2010, 9:03 pm
i ran my 528 with 200hp off the line and 200hp more,1second timed delay later 400hp in total.
i was using a nitrous works cross bar system it worked well for me.
it gave me another second on the quarter..use to run my cleveland with the same set up ran good for a long time..had to repace cranks every season as it use to chop out the centre main bearing..crant flex i guess.
procharger 528
procharger 528
Post  Barney May 1st 2010, 9:56 pm
I agree that the Victor needs work with that kind of tuneup. But i have sprayed a 110 squared which is about 345 or so so it can be done you just have to sneak up on it.
Barney
Barney
Post  bruno May 1st 2010, 10:14 pm
richter69 wrote:man thats a big hit for a plate, maybe when the new tfs intake comes out but with the victor I'd be careful.
x2 ... max would be 250 on a plate ..... the rest on the fogger
Post  Barney May 2nd 2010, 1:42 am
It can be done on a plate, but it isnt for the faint of heart and you REALLY need to work on the intake ALOT, and you have to be on your game with the tune, or you WILL hurt some outer cylinders. A fogger IMO is a little more forgiving with that kind of tune, but the plate is fun to play with too. Just take some time to learn what your combo asks for, the rest is just math and testing, testing, testing.
Barney
Barney
Post  Jeremiah May 2nd 2010, 2:58 pm
I have a NOS double cross bar plate with the 250 hit and a reg plate and super shot noids with the 100 on it..
Jeremiah
Post  bruno May 2nd 2010, 9:01 pm
so you are going to double stack your plates ?
Post  nuclearcobra May 3rd 2010, 7:10 am
Jeremiah wrote:I am 100% taking baby steps with this car... I was just asking for later down the road after I get my first kit lined out.. Just seeing what everyone was running and what they were getting out of it... Very Happy
Imo taking baby steps isnt starting with a 250 shot. you should start smaller and bump it up as you get everything lined out then you'll have a good time with it without killing your motor to find the best tune, trust me i've put holes in pistons with only a 100 shot when the tune was off (yes it was way off) but still only a 100 shot which i thought was safe even if the tune was off but not true.
nuclearcobra
nuclearcobra
Post  Jeremiah May 3rd 2010, 8:26 am
I started with motor then put a little 150 hot on it now wanting to run a 250 hit. So YES I did start small..
Jeremiah
Post  valleydawg May 4th 2010, 6:51 am
I spray 300 + on a stock block all the time. 100 plus passes. Keep check on the timing and fuel pressure and you should be good. I leak down my engine after ever race and it still is fine. I checked main and rod bearing two weeks ago before Pinks and everything is looking good.
valleydawg
valleydawg
Post  nuclearcobra May 4th 2010, 6:53 am
My bad i thought you were starting out with a 250 shot well be safe and have fun with it.
nuclearcobra
nuclearcobra
Post  Jeremiah May 4th 2010, 9:36 am
Steve is a hard man to get ahold of.
Jeremiah
Post  bruno May 4th 2010, 9:37 am
valleydawg wrote:I spray 300 + on a stock block all the time. 100 plus passes. Keep check on the timing and fuel pressure and you should be good. I leak down my engine after ever race and it still is fine. I checked main and rod bearing two weeks ago before Pinks and everything is looking good.
whats your tune ? what do your plugs look like ?
Post  valleydawg May 4th 2010, 1:03 pm
Bruno - I should have said have said I have two systems. 200 on the first (fogger) and grab 125 more (plate) .6 out. Plugs look good with a light grayish color if you look at them with a plug light. I run Autolite AR 3932 plugs. Although I do have a stock block it does have a girdle. Car ran 7.78 at Pinks and this was the first time in the ΒΌ.
valleydawg
valleydawg
Post  James Hahn October 8th 2010, 7:50 pm
Jeremiah wrote:Steve is a hard man to get ahold of.
Keep trying! Its well worth the wait!
James Hahn
Post  605FOX October 17th 2010, 8:46 am
x2 Steve can be reach on his cell 24/7 , he is a great help
605FOX
