C6 weak points
C6 weak points
What are the major weak points in a C6 transmission?
Just trying to work up an idea for what i need to do to prep the transmission for my bigblock.
Im going to be swapping the valve body out for a full manual with transbrake.
Any tricks or quarks that i should know about a C6?
Im pretty much C6 Dumb so im here here to learn up! Someone said its kind of like a C4 on growth pills.
Re: C6 weak points
https://www.429-460.com/transmission-tech-f7/rebuilding-a-c6-t2255.htm
Pics here of one i built with Frank M valvebody. Lots info in the sticky post on 460ford .
Gregaust- Posts : 625
Re: C6 weak points
Matt the C-6 will handle way more than you are ever going to put behind it.....
the Coug- Posts : 3055
Re: C6 weak points
I hope your right coug!
I drained the fluid out of it this morning and it looked all clumped up. Probably going to need a full rebuild. I like how the input shafts about 30 percent larger than my C4's
Got another question however, what gains would i see doing a roller conversion on the C6?
Re: C6 weak points
You'd most likely see a dramatic drop in tranny temps, which will make it live a lot longer. Heat is your worst enemy here!!!
torkair- Posts : 404
Re: C6 weak points
So going ahead and doing a roller conversion would probably be in my best interest then.
Re: C6 weak points
Maddmattmustangs wrote:So going ahead and doing a roller conversion would probably be in my best interest then.
Yes i believe so . They spin over much freer i have found with the rollers . At a minimum do the #9.
Re: C6 weak points
sounds good. What exactly will i need to do this?
» OT/weak spark
» Can/should I use this stock flex plate?
» Finally got the new motor running!
» Weak flow a460
» Starter shim or weak battery?
» Weak flow a460
