PG fitting ?
PG fitting ?
The trans cooling lines fittings, which one is for out (to the cooler) which one is return (from cooler)? Thanks
Re: PG fitting ?
The bottom line is pressure and the top is the return.
JB
JB
Treeyasoon- Posts : 759
Re: PG fitting ?
Most coolers don't car which direction the fluid flows, correct?
gryphon68- Posts : 51
Re: PG fitting ?
Correct.
» xxxxxxxxxxxxxxxxxx
» Water pump fitting
» Vent fitting on C6, best spot to tap?
» not fitting!! transfer case
» A fitting Photo for a special day.
