help me make a CREATIVE throttle control
+11
TommyK
bb429power
96Mustang460cid
342g
longroofracer
TRUKPULR
frank13
15 posters
help me make a CREATIVE throttle control Empty help me make a CREATIVE throttle control
Post  frank13 May 16th 2010, 10:30 pm
ok one of the last things to do for the car to run it is the throttle controls....
2002 mustang
edel carb (will be replaced with a 1050 in the next few monthes.....
i refuse to spend 50 bucks on a cheap spectre kit....
what have you guys done on the way cheap......i have the return springs, but need a way to mount the cable to control the carb....i just want something nice and cheap,,,,,not the usual buy it in a package kit.....
no kickdown is needed (manua trans)
please include clear pics and a list of parts i need to get!
thanks guys
frank13
frank13
http://www.frankskinkracing.com
help me make a CREATIVE throttle control Empty Re: help me make a CREATIVE throttle control
Post  Mark Miller May 17th 2010, 12:13 am
Frank,
On my 89 Mustang i'm using a old Ford throttle bracket bolted to my Victor Intake with a mid 70's Lincoln 460 Throttle Cable.I don't know if the 2002 Mustang has the same pedal set up as the 89,Later Mark.
Post  billandlori May 17th 2010, 4:28 am
Mark Miller wrote:Frank,
Same here, but the 83 Thunderbird cable fit perfect. The edebrock intake came with two spacers to raise the Ford bracket to where it needs to be.
help me make a CREATIVE throttle control DCP_0850
Here you can see the bracket (blue) and the stock cable.
Bill
Post  dfree383 May 17th 2010, 7:43 am
Locar and CSR make some really, really nice stuff.
The Specter Chrome Stuff is Flat out JUNK.
Post  TRUKPULR May 17th 2010, 8:48 am
OK Boys he don't want to spend the 50 buck on the cheap junk stuff. I'm sure the Locar and CSR stuff is way over his budget. But like the other guys have mentioned make a bracket that bolts on to the mounting bosses on the manifold and hook you throttle cable to it .
Dan
TRUKPULR
TRUKPULR
http://www.shazampulling.com
Post  dfree383 May 17th 2010, 10:48 am
Frank, Stop being so damn cheap...... Laughing
Post  Mark Miller May 18th 2010, 12:14 am
Bill,
That throttle bracket looks the same as mine what car did you get it from?
Later Mark.
Post  longroofracer May 18th 2010, 12:22 am
TRUKPULR wrote:OK Boys he don't want to spend the 50 buck on the cheap junk stuff. I'm sure the Locar and CSR stuff is way over his budget. But like the other guys have mentioned make a bracket that bolts on to the mounting bosses on the manifold and hook you throttle cable to it .
Dan
Just a quick search at Summit under Locar throttle cables... a bunch of them are under 60 bucks... almost 3 pages worth. Sometimes it is cheaper to look at what is readily available and sold often than trying to save a few bucks.
longroofracer
longroofracer
Post  342g May 18th 2010, 12:27 am
Mark Miller wrote:Bill,
Later Mark.
Yours.............. cheers ....... Laughing
342g
342g
Post  billandlori May 18th 2010, 3:34 am
Later Mark.
This one came from a 1977 Lincoln Town Car. I have used other ones from earlier 70's TC 460s also and they looked pretty much the same.
Nope it wasn't from Mark's car........ Suspect Very Happy Very Happy
Bill
Post  96Mustang460cid May 18th 2010, 8:49 am
Here is one I made from some ~16 gauge 1020CR.
help me make a CREATIVE throttle control 9-7-2007002
Basically, it's a triangulated bracket with a notch cut in it to hold the throttle cable. I had about 1 hour of time wrapped up in it.
Have a good day!
Michael
96Mustang460cid
96Mustang460cid
Post  frank13 May 18th 2010, 11:30 am
Ok I don't wanna spend the 50 on the spectre kit cause I know it's junk. I don't mind spending moneythough. I looked at the lokar stuff and I think csi. I like the trottle brackets from both. I just know some of you have done cool things with linkage and was curious for ideas.
frank13
frank13
Post  dfree383 May 18th 2010, 12:12 pm
frank13 wrote:Ok I don't wanna spend the 50 on the spectre kit cause I know it's junk. I don't mind spending moneythough. I looked at the lokar stuff and I think csi. I like the trottle brackets from both. I just know some of you have done cool things with linkage and was curious for ideas.
OK your off the hook on the "Cheap" statment......... Laughing We'll change it to "Creative"....
Post  frank13 May 18th 2010, 12:32 pm
FIXED
frank13
frank13
Post  bb429power May 18th 2010, 5:58 pm
96Mustang460cid wrote:Here is one I made from some ~16 gauge 1020CR.
Have a good day!
Michael
What the heck kind of carburetor is that? Never seen one like that all rounded off. Just wondering. confused
bb429power
bb429power
Post  TommyK May 18th 2010, 6:44 pm
speed demon
TommyK
Post  jbozzelle May 18th 2010, 7:44 pm
Didn't we fix 2 or 3 of them Lokar cables at the Bash last year?
If I remember correctly they all were stretched and the carb wouldn't open all the way...
If it were me I'd either gather up a factory deal or make a linkage from a piece of steel tubing, modify the pedal, etc... Wouldn't be that hard to do...
Post  frank13 May 18th 2010, 7:51 pm
jbozzelle wrote:Didn't we fix 2 or 3 of them Lokar cables at the Bash last year?
ok ...ow bout a diagram? i wouldnt mid making something up or finding a way to make the stock 02 mustang cable work.........just not sure how to attach the cable to the edelbrock carb....can i cut the cable and attach a fitting to go to the carb....i can make a braket...i have a few ideas now on the bracket and just need a good way to attach to the carb
frank13
frank13
Post  jbozzelle May 18th 2010, 9:50 pm
I'd measure from the carb to where the cable goes in the firewall and find a stock cable that fits that measurement. That 2002 cable is probably too long.
The cable hooks to the carb with a ball stud, just like a stock carb. You can buy those at the stores. The cable hooks to the pedal with a plastic grommet that just snaps in and out of the pedal.
I'd hit up a junkyard a look for a ford cable that will fit... You should be able to find everything you need there. Cable, bracket, ball stud, etc...
If you want to make a metal rod type just come off the pedal forward through the firewall then bend it towards the carb, then attach it.... You can buy a rod type linkage kit from Jegs.
Post  Mark Miller May 19th 2010, 1:07 am
Harold,That was funny my cable was still on there Sunday when i drove my car,maybe Bill took it after that.
Bill,i think my throttle bracket was off a 75 Lincoln.
Frank,a 83-85 Mustang 5.0 cable might also work.
John,i agree i have not had any problems with the stock Ford bracket and Lincoln cable.
Later Mark.
Post  GTmustang May 19th 2010, 9:02 am
Another issue with the Lokar cables is that the ball on the pedal end of the cable is too small for the plastic bushing in the pedal and will eventually pull through! You can reuse the inner cable from your stock throttle cable inside the Lokar sheath and brackets and attach it to the carb using the end from the Lokar kit ! A 1985 5.0 Mustang cable works also.
Gary
GTmustang
Post  nuclearcobra May 29th 2010, 8:38 am
Your right the ball end is too small but its a easy fix you just put a small washer on it and its fixed.
nuclearcobra
nuclearcobra
Post  whatbumper May 29th 2010, 2:41 pm
we try to use fox body throttle cables if we can. the early versions are shorter and the FI versions are longer but both will work with carb apps if you don't mind a little extra cable in the engine compartment with the latter. As far as brackets are concerned, we build our own from scrap metal.
Post  Doug Rahn May 29th 2010, 6:43 pm
I like the old tried and true rod type linkage.
help me make a CREATIVE throttle control DSCF0436
Post  whatbumper May 29th 2010, 10:26 pm
Doug Rahn wrote:I like the old tried and true rod type linkage.
did you make or buy that one? looks nice
