Starter????
+11
'65 T-BOLT
patfromjersey
342g
frank13
Tommyj466
D. Sea
bcr466
jason
15 posters
Starter???? Empty Starter????
Post  jason May 18th 2010, 2:44 pm
Hey there! What starter are you guys running? I have 12.0 comp. And Ive got a csr platinum .
jason
jason
Starter???? Empty Re: Starter????
Post  bcr466 May 18th 2010, 3:04 pm
Will be running the DB Electrical on this build. I had a Big End brand, looks exactly like Hitachi, still have it but the drive end housing was damaged when a rod came out by it and cant find another housing . Then there is the old standby, the stock starter, (heavy) that has been used off and on since 87.
bcr466
bcr466
http://cracing@frontiernet.net
Post  D. Sea May 18th 2010, 3:06 pm
Starter froa mid 90's 460 F250 with an automatic.
13.25:1 Compression 534CI
D. Sea
D. Sea
Post  Tommyj466 May 18th 2010, 3:08 pm
Cheap enough to buy an extra one for a back-up.
http://cgi.ebay.com/ebaymotors/NEW-FORD-F-TRUCK-STARTER-7-5L-460-CID-92-93-94-95-96-97-/390171791410?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item5ad80d1032
TJ
Tommyj466
Tommyj466
Post  dfree383 May 18th 2010, 3:09 pm
Same as Damon, parts store replacement factory mini starter, been in their for 6 years now. .
Post  frank13 May 18th 2010, 5:26 pm
picked one up from advanced auto for 50 with a lifetime warranty
frank13
frank13
http://www.frankskinkracing.com
Post  richter69 May 18th 2010, 5:35 pm
D. Sea wrote:Starter froa mid 90's 460 F250 with an automatic.
same here, and it really works good with 16volts...................
Post  342g May 18th 2010, 8:43 pm
frank13 wrote:picked one up from advanced auto for 50 with a lifetime warranty
what is the part number from advance?
342g
342g
Post  patfromjersey May 18th 2010, 8:48 pm
I have a Summit high torque mini starter, and it's been great for street use for over quite a few years now. Cool
Starter???? Starter01
patfromjersey
patfromjersey
Post  cool40 May 18th 2010, 8:51 pm
i've been useing the jeg's unit with no problems.it works good when the battery is even low. Smile
Post  '65 T-BOLT May 18th 2010, 8:56 pm
X 2 on the Jegs unit for the 521, prior to that a powermaster XS starter on the 427 sbf.
'65 T-BOLT
'65 T-BOLT
Post  frank13 May 18th 2010, 9:31 pm
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Starter-Worldwide_5220572-P_123_R%7CGRPSTRTAMS_539104030___
frank13
frank13
Post  56Tbird May 18th 2010, 9:41 pm
I've got a DB electrical on both cars. It spins this 16 to 1 557 just fine..and the old 472 starts great too...same as the 94 460 truck starter
56Tbird
56Tbird
Post  bbf-falcon May 18th 2010, 11:34 pm
Just ordered 2 dbelectric last week. They have to be modified before they will fit my TCI midplate/glide adapter plate. Using a modified Lakewood mini starter,it works great on LiL Tweety's 144 inline 6. Laughing
Post  D. Sea May 19th 2010, 12:19 pm
bbf-falcon wrote: LiL Tweety's 144 inline 6. Laughing
Uh-Huh Rolling Eyes Razz
D. Sea
D. Sea
Starter???? Empty DBelectric
Post  Rvesterby September 5th 2010, 10:12 pm
I pulled up the ad and it looks like the selonoid mounts below the starter or they have the pictiure negatives reversed (uncommon in the digitial world) Can anyone that has purchased the DB starter confirm if the selonoid locates on top (above) like the factory setup - are the pictures inverted ??
Rvesterby
Rvesterby
Post  CDMBill September 5th 2010, 11:30 pm
I ran the Summit model pictured above for five years street and track in al conditions with no trouble and it easily spun my 11:1 580" pump gas motor. It simply stopped engaging a couple months ago and I bought a Proform unit form Loper's in Phoenix which has worked okay, not quite the cranking RPM of the Summit unit and it needed to be spaced out about 3/32 for the gear to clear the flex plate. Summit says they can have theirs rebuilt and I have sent it off to have that done as I trust it more than the Proform. Do to its lower cranking speed I occasionaly get a kick back/back fire if it doesn't light off cleanly and goes off the start retard.
CDMBill
