Which Starter?
Which Starter? Empty Which Starter?
Post  rollercam1 May 19th 2023, 10:47 am
Having some starting troubles. The engine isnt anything special, 521, 10.5:1, hydraulic roller, .650" lift. The stock starter from 1969 has worked better than the high torque mini starter. I have all 0/1 welding cable for batter cables, all high quality connectors. Wont turn the engine back over if hot. What are you guys using?
rollercam1
rollercam1
Which Starter? Empty Re: Which Starter?
Post  rmcomprandy May 19th 2023, 11:05 am
rollercam1 wrote:Having some starting troubles. The engine isnt anything special, 521, 10.5:1, hydraulic roller, .650" lift. The stock starter from 1969 has worked better than the high torque mini starter. I have all 0/1 welding cable for batter cables, all high quality connectors. Wont turn the engine back over if hot.  What are you guys using?
Production O.E.M. gear reduction starter from a 90's 460 truck.
Be certain your ignition timing is correct.
Post  rollercam1 May 19th 2023, 1:08 pm
Interesting, I tried a used stock starter out of a 95' F250 7.5. and it didnt do any better than the 69' one. I have start retard on and the initial is 10 degrees till it spins 800rpm's. Worth a try to lower it though.
rollercam1
rollercam1
Post  lance flake May 19th 2023, 2:29 pm
rollercam1 wrote:Interesting, I tried a used stock starter out of a 95' F250 7.5. and it didnt do any better than the 69' one. I have start retard on and the initial is 10 degrees till it spins 800rpm's. Worth a try to lower it though.
I have seen timing to low cause cranking trouble also. It should start fine in the 10-20 range. You may try to get engine spinning the flip ignition on.
lance flake
Post  stanger68 May 19th 2023, 7:06 pm
I agree with lance. My 557 wont crank with less than 17. But its 13.25:1 and on methanol. Different animal but still too low is just as bad as too high.
