main girdle info
bb429power
Diggindeeper
RapidRuss
main girdle info Empty main girdle info
Post  cool40 May 20th 2010, 11:56 pm
i pulled the bullet out for a little "update"and thought i'd share some info.my 526,a heads,flat top's & oliver rods had a ford racing girdle on it.it's aluminum and had all the studs and such with it as i got it new when i built this thing about 5yr ago.after 200 or so passes with a cam change in the mix it's saw 6800-7800rpm but mostly in the 7200 range.i know this has been beat to death i just wanted to share what i found.this aint my first build so it's nothing new to see cap walk,and cap walk i did see.i dont see any good the girdle did for this one but who knows,it coulda been all that kept it together. Laughing i do have a cure for cap walk,i'll post it later. Laughing main girdle info New_st17main girdle info New_st18
main girdle info Empty Re: main girdle info
Post  the Coug May 21st 2010, 12:15 am
They are just snake oil they do not work what so ever...... I have seen to many and never have they ever stopped cap walk...... the only thing I have seen them do is remove cash from your pockets, Nothing else.....
Post  cool40 May 21st 2010, 12:22 am
i'v been tryen to think of something to make out of it. Laughing
Post  the Coug May 21st 2010, 12:25 am
sell it to someone that think they are so needed, get part of your money back at least...... only way to stop cap walk is 4 bolt mains...
Post  RapidRuss May 21st 2010, 6:06 am
Yep Randy is right on there, I have delt with the Ford FE's for a number of years, and have seen alot of cap walk when the motor starts making some good hp...the only way I have ever seen to eliminate it was either a set of pro-grams 4 bolt caps, or some guys will use the old 427 ford crossbolt caps..Problem gone...I have even seen some drill and dowel the main registers and caps, But have never seen them tore down for a re-fresh to see if it worked.. I think the cost of having the block machined for the new 4 bolt caps is around $300, but then of course you'll want to line hone the main caps and saddles again, I'am not sure of what the line hone goes for..But the cost of the caps @ $300+ and another min of $300 in machine work plus the line hone...you can see you'll get into some cash..Now these prices are a few years old now... I was going to do this to my 428CJ motor, as I wanted to take it up close to a max for the block... To run in my 70 F250...But then I have been thinking well hell...For the all the machine work needed to get the block to handle that kind of hp...and the price of FE parts today..I think I'd be ahead of the game selling my block and intake, crank etc...and just buying a A460 block from Lem and be done with it..and do the conversion in my truck.... and that will still give me room to grow at a later date.. JMO... Smile
RapidRuss
RapidRuss
Post  Diggindeeper May 21st 2010, 9:52 am
i bet the dowels work better than the girdle.
the girdle still relys on the clamping force of the bolt (or stud) in this case. (seeing how hardly any of it touches the cap)
at least with a dowel there is not 30 thousands clearance around it in the hole.
Diggindeeper
Diggindeeper
Post  cool40 July 6th 2010, 9:56 pm
cool40 wrote:i pulled the bullet out for a little "update"and thought i'd share some info.my 526,a heads,flat top's & oliver rods had a ford racing girdle on it.it's aluminum and had all the studs and such with it as i got it new when i built this thing about 5yr ago.after 200 or so passes with a cam change in the mix it's saw 6800-7800rpm but mostly in the 7200 range.i know this has been beat to death i just wanted to share what i found.this aint my first build so it's nothing new to see cap walk,and cap walk i did see.i dont see any good the girdle did for this one but who knows,it coulda been all that kept it together. Laughing i do have a cure for cap walk,i'll post it later. Laughing main girdle info New_st17main girdle info New_st18
i got the cure! Laughing main girdle info Idt_0010
Post  bb429power July 6th 2010, 10:16 pm
RapidRuss wrote:..and do the conversion in my truck.... and that will still give me room to grow at a later date.. JMO... Smile
You don't need to buy a conversion at all for your truck. My truck is setup EXACTLY the same as yours. FE engine perches for the stock FE engine. But the engine was a 429 and there was never any conversion put on it. Stock 429 motor mounts rested on FE perches and the motor and trans just drops into place. I know of another guy who did the same thing, never had a single problem putting the motor and trans in. So you can knock that expense off of your list, 67-72 ford trucks are VERY similar with parts and looks. For all model trucks except the f600, that's another story in itself.
bb429power
bb429power
Post  bb429power July 6th 2010, 10:18 pm
How do you identify main cap walk, to be exact? study I'm leaching Very Happy
bb429power
bb429power
Post  cool40 July 6th 2010, 10:24 pm
bb429power wrote:How do you identify main cap walk, to be exact? study I'm leaching Very Happy
the main cap will "walk" on the block and make places that look kinda like you srtuck an arc with a stick welder on it.it's a sure sign your shit was close to the point of no return. Laughing
Post  bb429power July 6th 2010, 10:32 pm
Okay, thanks. i couldn't really find any spots like that on the cap. But just behind the stud on the left I see a few. But you know how it is, its MUCH easier to see in person.
bb429power
bb429power
Post  cool40 July 6th 2010, 10:35 pm
very easy to see with the eye,not so much with my pic's. Laughing
Post  bruno July 6th 2010, 10:44 pm
can you get a good torque reading with those allen head bolts ????
http://WWW.CKRME.COM
Post  res0rli9 July 6th 2010, 10:46 pm
bruno wrote:can you get a good torque reading with those allen head bolts ????
WHY NOT??
Post  bruno July 6th 2010, 10:48 pm
just asking a question ...... but that doesnt seem like an answer scratch
Post  res0rli9 July 6th 2010, 10:52 pm
I wasn't trying to be a smart ass. was just asking why would it be any different reg. bolt head or nut ??
buy the way.. nice block Cool
Post  bruno July 6th 2010, 10:54 pm
so then what is the reasoning to have two diff style fasteners on the caps ? ....from what i read the allen head can be a superior fastener in most applications ......
Post  cool40 July 6th 2010, 11:29 pm
the reason for the bolts is room Idea they are very close to the center part of the cap and they are splayed.
Post  res0rli9 July 6th 2010, 11:52 pm
OK. I see why Nick asked the ?. but now I have one. why is the allen head better for torque.. just trying to learn something new.
Post  cool40 July 7th 2010, 12:09 am
res0rli9 wrote:OK. I see why Nick asked the ?. but now I have one. why is the allen head better for torque.. just trying to learn something new.
it aint.it's no better than the bolt in the center and should'nt be any trouble to torque.most allen bolts are better grade than your parts store grade 5 stuff but not automotive bolts. Smile
Post  DanH July 7th 2010, 7:25 am
the Eliminator premier has 12 point head A1 outer bolts
DanH
Post  chuck stevens July 7th 2010, 12:07 pm
True, but...........the PREMIER block is 2 steps up from the ULTRA. Cool
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  cool40 July 7th 2010, 1:17 pm
chuck stevens wrote:True, but...........the PREMIER block is 2 steps up from the ULTRA. Cool
how so?the website claims the ultra is a premier with cast caps. Smile
Post  chuck stevens July 7th 2010, 9:45 pm
The progression is: ULTRA ( with cast nodular iron caps), ULTRA (with billet steel caps), PREMIER (with billet steel caps).
chuck stevens
Post  cool40 July 7th 2010, 9:52 pm
chuck stevens wrote:The progression is: ULTRA ( with cast nodular iron caps), ULTRA (with billet steel caps), PREMIER (with billet steel caps).
hmmmmmm,lesson for the day.i was just looken at what they have on eliminatorproducts.com.thanks for the info. Smile
