Lastest suspension issues
+8
342g
DFI429
Barney
12 posters
Page 2 of 2 Previous  1, 2
Lastest  suspension issues - Page 2 Empty Re: Lastest suspension issues
Post  richter69 June 1st 2010, 11:25 pm
'65 T-BOLT wrote:
richter69 wrote:
'65 T-BOLT wrote:new slicks!
uhh yes........
make you a smokin deal on some W's............... Razz
I was saying that he needs some new shoes.
yes I agree.............
Post  '65 T-BOLT June 1st 2010, 11:27 pm
richter69 wrote:
'65 T-BOLT wrote:
uhh yes........
cool! as for I am not the smartest! glad that i called that one correct then about Nick needing new shoes
'65 T-BOLT
'65 T-BOLT
Post  DILLIGASDAVE June 1st 2010, 11:45 pm
richter69 wrote:make you a smokin deal on some W's............... Razz
Here "W"e go.... Razz
Post  whatbumper June 2nd 2010, 12:05 am
bruno wrote:
whatbumper wrote:I just noticed this thread and am blocked from photobucket here and my phones screen is too small so I will watch it later but.... I would run 13.5-15 psi of air with a hard hitting nitrous motor in a fox on that tire. I never ran tubes but that is up to you.
Have you scaled the car? What are your corner weights? How are your lowers set up? Do you have any preload on your ARB? What front/rear springs? Front strut setting? Rear shock setting? Any limiters? There are a lot of variables that we use to setup a car. It IS possible to set up a car to 60' hard and not kill the sidewall as much but it is just the nature of the beast that tires will not last you that long at your torque level at your weight.
1- never scaled car
2- dont know
3- laddr bar suspension
4- zero preload in arb
5- strange up front set on #5
6- yes have limiters , but disconected them for that launch
7- double adjustable rears ...have to ck ... i think they are all in the center
8- rears are 1 1/2 old with 50-60 passes on them
I'm sorry. I thought we were talking stock suspension.
New sicks (sidewalls are dead), limit the front, more air, stay with that shock setting. back looks really good now knowing it is ladder bar.
Stay away from those damn W's. lol cheers
Post  bruno June 2nd 2010, 6:35 am
should i limit the front via stiffening the shocks or should i install the limiters a notch ?
http://WWW.CKRME.COM
Post  DILLIGASDAVE June 2nd 2010, 8:25 am
bruno wrote:should i limit the front via stiffening the shocks or should i install the limiters a notch ?
If you have both, use both.
Each helps to control front end rise, but in different ways. One controls the total extension travel, the other controls the total speed at which the extension travel happens.
Post  whatbumper June 2nd 2010, 9:37 am
agreed. small amounts though.
