What engine coolant?
What restrictions, if any are there on the engine coolant used in a drag car? Can I run antifreeze at a NHRA or other drag strip?
What is the best coolant to run withan aluminum head 545?
airford1- Posts : 192
Re: What engine coolant?
On a drag car you shouldn't have any antifreeze because it is an absolute B!%@# for them to clean up when it leaks. That stuff can get you in some serious trouble.
bb429power- Posts : 3129
airford1 wrote:What restrictions, if any are there on the engine coolant used in a drag car? Can I run antifreeze at a NHRA or other drag strip?
Plain WATER is the best coolant however, it will boil at 212° at sea level so, somehow raising the boiling tyemperature of the coolant should be done.
Anti Freeze which is Ethelene Glycol is a NO-NO at any NHRA event and not a good idea anywhere else either. (It is almost impossible to clean-up).
Raising the boiling temp of the coolant can be accomplished with using about 25% PROPOLENE GLYCOL based anti freeze, (which is of course more expensive), added to the water.
RACING anti freeze IS Propolene Glycol but, it is also available at your local parts store under the brand name of SIERA.
So water is what everybody is using? No additives to slow electroisis?
airford1 wrote:So water is what everybody is using? No additives to slow electroisis?
Anti Freeze is blended with Electrolosis controling chemicals.
You're question was indicating this was for drag strip use .. a tablespoon of baking soda will help comtrol the electrolosis if that is your major concern.
we get our coolant from here.
whatbumper- Posts : 3024
I'm sure you were born knowing everything and I bet you never asked only learning the hard way,,,,,,,,,,, "The School of Hard Knocks".
Thanks. Sorry for not knowing, That's why I asked.rmcomprandy wrote:airford1 wrote:So water is what everybody is using? No additives to slow electroisis?
just plain water here......from the wash rack at work, with one bottle of water wetter...............no radiator..................
No antifreeze at the track.
» Coolant filter's
» nhra approved evans waterless coolant any users ?
» coolant leak,
» 6.0L coolant leak
» Coolant Test?
» coolant leak,
» 6.0L coolant leak
» Coolant Test?
