Fly cutting pistions
+12
138
raysmust
jones
16 posters
Page 2 of 4
Page 2 of 4 • 1, 2, 3, 4
Re: Fly cutting pistions
raysmust wrote:Hey Randy,
Everyone is good over here, busy like always.
How are you doing?
NOT busy ... wish I was; as in year's past.
Everbody wants to build a winning combo, trouble is if you dont have the cash to do it right now either the class is gone or gotton too fast by the time you get it done. My buddy with the outlaw car is a perfect example...............
Since i built this stroker motor its had a lot of changes..............have even made changes since the last time it was out..............its part of racing.............
I know I can't be competitive in heads up racing but I can race in the index classes. When I started this long build I was wanting to keep the truck streetable. Which making something streetable and fast and safe is exspensive proposition. I figure I'll just turn it into a race truck and save the money needed to make the thing streetable. The most important thing for me is to (A) get it finished, (B) not be the local laughing stock for working on something for so long. Only to go from a 8.0 et to 7.0 et. I expect to have the means to propel this 4,000lb truck down into the 6's if not high 5's once the suspension is right. (naturally asperated)
I'd like to run 6.0 index races.
jones- Posts : 2230
5's n/a at 4000#..............sell it all, buy some A460 heads, 570" motor.............lots of $$$$$$$jones wrote:I know I can't be competitive in heads up racing but I can race in the index classes. When I started this long build I was wanting to keep the truck streetable. Which making something streetable and fast and safe is exspensive proposition. I figure I'll just turn it into a race truck and save the money needed to make the thing streetable. The most important thing for me is to (A) get it finished, (B) not be the local laughing stock for working on something for so long. Only to go from a 8.0 et to 7.0 et. I expect to have the means to propel this 4,000lb truck down into the 6's if not high 5's once the suspension is right. (naturally asperated)
Like I said, that is my goal. Might have to use a little nitrous and I'm pretty sure I can get the truck weight down to 3,500lbs
Wish I could sell it all and build what I originaly wanted.
jones- Posts : 2230
after seeing Dougs Truck thread one could probably get it down alot more.
Jones remember you have a cast crank and you are about to step out of it's boundry.... go as fast as you want to go will put you way up in HP...... now you have a buch more weaker parts.......(crank,Block)
JMHO
JMHO
the Coug- Posts : 3055
The Coug is correct, a set of good street heads will give that shortblock fits..............hence my sell it all and $$$$$$ comment.
Jon A460 heads are not going to get that tank into the 6.0 or 5.9 class remember it weighs in at #4000...
the Coug wrote:Jon A460 heads are not going to get that tank into the 6.0 or 5.9 class remember it weighs in at #4000...
Oh you could make the power, not cheap but doable. Gonna need more than a set of caltracs to compliment it though...........
I'd just rather see a brother do some racin' instead of keep changing the combo and never getting anywhere.............
The joys of indecision!
jones- Posts : 2230
richter69 wrote:the Coug wrote:Jon A460 heads are not going to get that tank into the 6.0 or 5.9 class remember it weighs in at #4000...
x2run it and stop changing untill you know what ya got!!!
Did I read 6.0 in the eigth with a 4,000 pound truck and those engine parts NA ...?
That's almost a rediculous goal to set ... maybe around 7.0 ... !
rmcomprandy wrote:Did I read 6.0 in the eigth with a 4,000 pound truck and those engine parts NA ...?
Yes, my goal is to run 6.0 in the 1/8mile
Like I said, good chance of getting the truck down to 3,500-3,600lbs. I didn't think 6.0 in the 1/8 would be that hard to accomplish. The track elevation is around 400' above sea level.
Ok I might be wrong and have to settle for starting in the 7.0 index classes. Like I said though, my 79 that weighed over 4,600lbs was running 8's in the 1/8 mile with a 100,000 mile engine and 0 oil pressure. Is 2 secs really to much to expect out of this built combo? Not like I am wanting to run 4's like everyone else.
jones- Posts : 2230
Jones 8 flat in the 1/8 is 12.50 in the 1/4
6 flat in the 1/8 is 9.30's in the 1/4
Yes one hell of a difference.....
6.0's is definetly fast !!!
i would have to say you are gonna need atleast 900-950hp at that weight (3600lbs)to run 6.0's and you are gonna have to be really dialed in on your suspension .......
and 600-650 hp to run some solid 7.0's @ 3600lbs
Not only the weight but the wind resistance of a truck is working against you.
6.0's is movin', if you had kept the mustang your combo would have been close...........
Hell Doug is close to that, but his truck is light and motor no slouch, good converter, glide, big tires and good suspension to boot.
Damn,,
Well, you know there is nothing wrong with having dreams I guess. LOL Sucks when you have to turn your plans into dreams!
I think I am going to stay with the design I have and not open up another can of worms.
jones- Posts : 2230
richter69 wrote:Not only the weight but the wind resistance of a truck is working against you.
Much much higher elevation too!
jones- Posts : 2230
but the better numbers were at a lower elevation if I'm correct.
from his sig.................
'86 F150......
521 w/FRPP SCJ heads, Glide, & 5500 UCC Converter...
Best ET: 1/8: 6.34 @ 112 mph N/A @ 5000' 6.17 @ 112 mph N/A @ 1200'
Best ET: 1/4: 9.97 @ 135 mph N/A @ 5000' 9.73 @ 136 mph N/A @ 1200'
'86 F150......
I see,
Lot of nitrous------!!CHECK!!
jones- Posts : 2230
HeRo's dont use nitrous.........
richter69 wrote:HeRo's dont use nitrous.........
HeRo's, Date ugly women, drink warm beer, eat rocky mountian oysters (with white sauce), sleep in their cars and don't call thier Moms on mothers day too, So whats your point?
I'm no hero, just a zero! Cheesy huh??
I just got to much time to think about it, if I didn't have to save as I go I would have put a strick engine build list togather and stuck too it. Instead, by not having the parts rolling in and being built, I opened myself up to second guessing. IMO
jones- Posts : 2230
To put it a little into real life perspective -
At the previous bashes, (not the 2010 bash), who remebers the match races between Wes' truck and George Keown's truck ... ? Those trucks were running barely better than 6.0 at high 5.8's.
» Fly cutting pistons
» Tool for cutting pedlestals down
» Cutting for springs/pc seals ?
» engine cutting out under load
» Back cutting
» Back cutting
Page 2 of 4
