Fly cutting pistions
+12
138
raysmust
jones
16 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Fly cutting pistions
I guess there is nothing wrong with starting in the 7.0 index classes.
jones- Posts : 2230
Jones 7.0 still gonna put you in the 10.90's 1/4 mile.... not to shabby for a Tank...
the Coug- Posts : 3055
the Coug wrote:Jones 7.0 still gonna put you in the 10.90's 1/4 mile.... not to shabby for a Tank...
Heck if it can't run 10.9's then it needs to stay at the house! I just sponsored a race I called "Truck Wars" and almost every truck that showed up for the event ran mid 10's. Atleast bracket raced with mid 10's, daily driven full size sbc street trucks run mid 10's, Gen II Lightnings run mid 10's. Then there is the race trucks that run 9's. Something isn't adding up! Either we have a lot of fast trucks in my area or ya'll have no faith in my build.
My local screen name is "Move" I am trying to get a local truck series going. So when I do have my truck running I might have another class to race in. (see Truck Wars) Probably just run the ODRA from now on.
jones- Posts : 2230
What does Kieth's truck run? (Copper Head)
IDT-572 wrote:What does Kieth's truck run? (Copper Head)
I thought he ran mid 10's in the 1/4
jones- Posts : 2230
richter69 wrote:HeRo's dont use nitrous.........
HeRo's don't need nitrous!!!
Nevs- BBF CONTRIBUTOR
Truth is there are some door car guys here with some decent power struggling to run the 6.0's..........
a guy once said to me that you greatest strength should also be you greatest flaw... in this case perfection
138- Posts : 1593
I came here because I wanted to see a fly cutting pistons....
Alas...I leave disappointed........
Mark O'Neal- Posts : 286
Sorry to disappoint ya!
Do you care to share on what you believe the minummum material thickness you need bellow the valve relief?
Why do people call it fly cut? I want to called them notched, milled?? Fly cut makes me think of a cylinder head or block decking.
jones- Posts : 2230
It's probably called "fly cutting" because before specialized cutters were made, people used a fly cutter in a milling machine.
jones wrote:Do you care to share on what you believe the minimum material thickness you need below the valve relief?
Over a broad area .150. I've done them as thin as .060 in a small spot where it get thick very quickly.
I'm assuming N/A.
Thanks, Mark!
Lem, thanks for the picture. Surprised to see how far in the valve sits from the cylinder wall. Doesn't apear as likely to cause a hot spot.
jones- Posts : 2230
Lem Evans wrote:Vavle off the cyl. wall is good for flow too.
....pretty "fly"............for a white guy................
triple fly ......my old deal
bruno wrote:triple fly ......my old deal
What is that giant notch for? Looks like the pistons was used in another engine then turned down to fit into your engine. Looks like you had to have the block notched for that valve.
jones- Posts : 2230
here are some better pics
there was no notching on the block Josh ..... Lem had looked at these pics i believe before and i cant remeber what he said ........
waste of potential compression......
The block was decked on that deal also
That big notch was a screw up.....................
» Fly cutting pistons
» Tool for cutting pedlestals down
» Cutting for springs/pc seals ?
» engine cutting out under load
» Back cutting
» Back cutting
Page 3 of 4
