Need a light weight spool
Need a light weight spool Empty Need a light weight spool
Post  bbf-falcon June 15th 2010, 11:09 am
Guy's,I need a 35 spline light weight spool(not Alum)and it has to fit a Strange case. Mark Williams won't fit,they are too big.
Need a light weight spool Empty Re: Need a light weight spool
Post  56Tbird June 15th 2010, 11:25 pm
That's what she said!! affraid
56Tbird
56Tbird
Post  Treeyasoon June 17th 2010, 9:14 am
Are you looking for a new or used one?
Treeyasoon
Treeyasoon
Post  bbf-falcon June 17th 2010, 9:28 am
Good used one will be fine.Can't be a Mark Williams though,they are to big to fit in the case.
Post  Treeyasoon June 17th 2010, 9:46 am
I may have a line on one...I'll check this afternoon.
Is it a 3.062 or a 3.250 case?
Are the axles Strange too?
Treeyasoon
Treeyasoon
Post  DanH June 17th 2010, 4:51 pm
Treeyasoon wrote:I may have a line on one...I'll check this afternoon.
Strange does'nt have a 35 spline 3.062 case spool
DanH
Post  bbf-falcon June 17th 2010, 10:26 pm
I haven't ordered the axles yet,but will most likely be Moser
Post  Treeyasoon June 17th 2010, 10:26 pm
You indeed have a keen sense for the obvious sir....
Treeyasoon
Treeyasoon
Post  Treeyasoon June 17th 2010, 10:40 pm
That is why I asked about the axles....You can get a Richmond spool for a 3.062 case...35 spline. I thought I knew where a used one was but, it is already spoken for.
If you go with a Richmond piece, just make sure to tell Moser that you want the splines cut for a Richmond spool. The Moser 35 spline will not fit a Strange 35 spline or a MW 35 spline and so on.
I've already been down this road... https://www.429-460.com/chassis-tech-f3/9-3062-vs-3250-minor-dilemma-opinions-wanted-t4178-15.htm#50291
Be sure to read the last post about the splines running through the spool.
Jeff
Treeyasoon
Treeyasoon
Post  DanH June 18th 2010, 12:29 am
one other thing to let the axle companys know , the brake manufacture that will be used.
DanH
Post  dfree383 June 18th 2010, 7:37 am
I've alway been under the impression that only the Mark Williams stuff used a different spline angle and their stuff wouldn't interchange? I've swapped between Strange, Moser and others before with out issue 28 & 31 stuff
Post  bbf-falcon June 18th 2010, 8:40 am
dfree383 wrote:I've alway been under the impression that only the Mark Williams stuff used a different spline angle and their stuff wouldn't interchange? I've swapped between Strange, Moser and others before with out issue 28 & 31 stuff
X2 scratch I know a racer friend that has a Strange Alum. case w/33 spline Moser Axles Exclamation
Post  Treeyasoon June 18th 2010, 10:10 am
When you call Moser to order your axles, they will ask you what brand of spool you are going to use...there are subtle differences between different manufacturers.
Treeyasoon
Treeyasoon
