Light weight calipers
Light weight calipers Empty Light weight calipers
Post  IDT-572 February 7th 2012, 12:33 am
Does anybody know of a light weight aluminum caliper to bolt to the factory mounts on a fox?
Light weight calipers Empty Re: Light weight calipers
Post  richter69 February 7th 2012, 12:23 pm
seen a few up at Duffy's and i think they had the Strange stuff on them, My kit I bougt had the caliper and pads, spindle and rotor.
REM coated bearings and oil bath lubed bearings are awesome............... Idea
Post  Barney February 7th 2012, 12:37 pm
X2 on strange.
Barney
Barney
Post  IDT-572 February 7th 2012, 3:55 pm
Thanks guys , trying to pick some weight off the car, those cast iron calipers are heavy.
Post  jbozzelle February 7th 2012, 5:10 pm
Strange for me as well. Mine are still in the box though. I have fooled with a few sets from Aerospace as well.
Post  IDT-572 February 7th 2012, 5:24 pm
jbozzelle wrote:Strange for me as well. Mine are still in the box though. I have fooled with a few sets from Aerospace as well.
Will yours bolt to the factory brackets?
Post  jbozzelle February 7th 2012, 5:28 pm
Yes. You need to modify the factory spindle in regards to removing the dust shield and drilling some holes larger and tapping them.
Post  IDT-572 February 7th 2012, 5:32 pm
jbozzelle wrote:Yes
Cool i WILL CHECK THEM OUT.
crap
Post  IDT-572 February 7th 2012, 6:01 pm
jbozzelle wrote:Yes. You need to modify the factory spindle in regards to removing the dust shield and drilling some holes larger and tapping them.
Can you get me the part number ?
Post  Barney February 7th 2012, 8:49 pm
I have Aerospace on mine. The Strange are a lot easier to package than the Aerospace. The Aerospace are good though, just kind of a pain dealing with the spacers.
Barney
Barney
Post  IDT-572 February 7th 2012, 10:21 pm
I have Lincoln mark seven spindles and rotors on mine, don't know if that matters.
Post  jbozzelle February 8th 2012, 11:39 am
IDT-572 wrote:I have Lincoln mark seven spindles and rotors on mine, don't know if that matters.
You might need to switch back to some regular Fox spindles. I'm about to buy some Racecraft or PA Racing spindles for mine to go with the Strange brakes. I still have the SN95 stuff on the front and it doesn't allow my wheels to fit.
http://www.strangeengineering.net/ Page 98 is all the part numbers. I'm using the B4142WC kit. I'm switching to the 5 x 4.75 bolt pattern
Post  IDT-572 February 8th 2012, 11:52 am
Post  Doug Rahn February 20th 2012, 9:14 am
I'm going with Strange also to cut down on some weight, but I haven't made up my mind yet on who's spindle to use. The stock spindle is 11 lbs., Racecraft's is 5.4 lbs., and PA's is 4.5 lbs. from what I can find out. Both Racecraft and PA are available with 2" drop, but the PA is also available in stock height. On the other hand Racecraft has the steering arm dropped 1" which would also allow me to lose the bump steer spacer on the rod end. Decisions, decisions scratch .
Post  jbozzelle February 20th 2012, 11:44 am
I think PA has a spindle with a dropped arm too. I'm running his kmember with a dropped pinto rack. That's why I planned to use his spindle. He mentioned it would all line up real nice.
Post  Doug Rahn February 20th 2012, 11:47 am
I just got a reply from PA about the weight on their spindles,
They weight no more than 6.5lbs each.
Post  bruno February 20th 2012, 1:39 pm
i run the aerospace deal on my and love them ........ i need to ck on those light weight spindles
http://WWW.CKRME.COM
Post  jbozzelle February 20th 2012, 3:03 pm
I've had excellent luck dealing with Jason at PA in the past.
Post  Doug Rahn March 1st 2012, 4:29 pm
UPS delivered my Ultralight spindles from Racecraft today, very nice pieces. Still waiting on the Strange brakes.
Light weight calipers UltralightSpindles003
Light weight calipers UltralightSpindles002
Light weight calipers UltralightSpindles001
Post  IDT-572 March 1st 2012, 4:30 pm
Those are sweet Doug................ I need a set of them do the come in a drop spindle?
Post  Doug Rahn March 1st 2012, 4:34 pm
IDT-572 wrote:Those are sweet Doug................ I need a set of them do the come in a drop spindle?
Yes, these are 2" dropped. Wink
Post  bruno March 1st 2012, 4:36 pm
Doug ,
what else do you have to change with there spindles ? will my existing brakes/struts/a-arms work with those ?
Post  Doug Rahn March 1st 2012, 4:44 pm
bruno wrote:Doug ,
Struts and A-arms should, I don't know about your brakes. You might need to call them. The brakes I ordered are their part #330013 for the Ultralight spindle.
Post  jbozzelle March 1st 2012, 4:47 pm
What PN are those?
Post  Doug Rahn March 1st 2012, 4:52 pm
jbozzelle wrote:What PN are those?
P/N 300116.
Nick, you have Aerospace brakes, right. They have a hub kit that converts your 79-93 Mustang Aerospace Brake Kit to fit the Racecraft Inc. Lightweight 2" Drop Spindle 300116. Like I said, it might be a good idea to call.
