Original TFS CJ head - tell us about them.
I have heard of them but really don't know much about them. Good? Bad? Indifferent? I think I've only seen 1 picture of them and they were on a motor. I have seen some for sale a couple of times, but they must not have been produced in very large numbers because they seem fairly scarce.
What's their story?
What's their story?
BigBlockRanger- Posts : 1267
Re: Original TFS CJ head - tell us about them.
Pretty much the same as a A429 or Factory CJ head in configuration.
I agree with what Dave Freelander has said above. I have an old 1999 Trick Flow catalog and the PN is TFS-52436001. They took the 2.250" intake valves and the 1.760" exhaust valves. Furthermore it states that they are Street heads, and "are designed to be a direct replacement for stock cast iron CJ and SCJ heads. Not only are they lighter, (saving 90 pounds) the heads have an intake port design that flow like ported stock intakes for even more airflow. Available as bare castings, the heads have 72cc combustion chambers, accept valve springs up to 1.625" diameter, and other production type valve components."
The ends of the head are cast in appearance and have a recessed flat area with the words Trick Flow cast in the head. They also made a matching 180* dual plane intake manifold with PN TFS-58247001.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Thanks for the info guys. Did they have any common maladies? I'm thinking along the lines of porosity or easily stripped threads or valve clipping? That kind of stuff. I am fascinated by older go-fast stuff for some reason....
I've never owned as set, but have never heard anything bad about them.
Decent head....could tell ya more about them but run the risk of getting flamed by all of the heroes on here........ask them.......D
devildog- Posts : 56
Good solid unbiased and usefull info doesn't get flamed. Outrageous, or unsupported info will be questioned. Useless info gets flamed.devildog wrote:Decent head....could tell ya more about them but run the risk of getting flamed by all of the heroes on here........ask them.......D
schmitty- Posts : 4538
So Schmitty you are big daddy approval committee?....guess you are in the hero group now.....I will be sure and clear any post with you prior to doing so.........thnx for helping me out .....D
There is only one HeRo, and I am HiM, I only flame when one is inquiring about a procomp item, these are not..............carry on.
devildog wrote:So Schmitty you are big daddy approval committee?....guess you are in the hero group now.....I will be sure and clear any post with you prior to doing so.........thnx for helping me out .....D
This post was not previously approved by Big Daddy and as such will be put in the recycle bin for later review of possible content.
richter69 wrote:devildog wrote:Decent head....could tell ya more about them but run the risk of getting flamed by all of the heroes on here........ask them.......D
did someone say....... Procomp???? Let me tell you about Procomp.......
dfree383 wrote:richter69 wrote:devildog wrote:Decent head....could tell ya more about them but run the risk of getting flamed by all of the heroes on here........ask them.......D
I was actually thinking about getting a set for my little street truck deal..............then I came to my senses lol.
Wait, are you referring to the heads manufactured under the company of ProCRAP? If not, then carry on. Devildog, I believe the term you are referring to is HeRo, never heard of a hero. I just wish I was there to here Lem say it so I knew exactly how he said it. Then it would be a bit funnier to me........dfree383 wrote:richter69 wrote:devildog wrote:Decent head....could tell ya more about them but run the risk of getting flamed by all of the heroes on here........ask them.......D
And Procomp is like the term, Chevy power. Its an oxymoron. Oh that's good, that's goin in my signature.
bb429power- Posts : 3129
Whiskey Tango Foxtrot
Guess everyones bored!?!?! LOL
» Biggest intake seat insert a Dove head will accept, trying to save head from dropped valve.
» Will Jesel Rockers From A Yates Head Work On A C-460 Cylinder head?
» coolant leak between head and block at head bolt location.
» P-51 Head's /Head Studs/pushrods (SOLD)
» P51 Head HP gain after head port
