dyno question
+10
DanH
LivermoreDave
kjett
14 posters
Page 2 of 2 Previous  1, 2
dyno question  - Page 2 Empty Re: dyno question
Post  bbf-falcon July 6th 2010, 12:51 pm
A friend and me were talkin and seems it would be a waste of time to Dyno a engine in 95* weather and very high humidity. because you will have to completely change the tune when the weather is normal. Seems it would be better to wait until the heat/humidity drops a bit.jmo Smile
Post  342g July 6th 2010, 3:22 pm
DanH wrote:dyno test air pans and scoop's , just look at your ET card .
I did this very thing Sat. night, I made my first pass without the air pan, shifted at 6200, ran 6.134, next pass put pan on car, same shift point, 6.101, next pass, moved shift point to 6500, went 6.088, then elimanations started, I dialed 6.08, went 6.085, left same dial on, went 6.082, next pass, dialed 6.07, went 6.081, left 6.07 on window, went 6.080, that was the end, had a -.005 light, but was a good test and tune night, temp was about 88, humidy was about 70%, barometric pressure was around 29.25, end of story. cheers
342g
342g
Post  richter69 July 6th 2010, 5:06 pm
so how you likin that APD carb?
Post  342g July 6th 2010, 5:52 pm
Carbs fine, I just need someone to help me with the jetting, and air jets, I believe there is more to be had, if I can figure it out.
342g
342g
Post  rmcomprandy July 6th 2010, 6:54 pm
342g wrote:Carbs fine, I just need someone to help me with the jetting, and air jets, I believe there is more to be had, if I can figure it out.
You need to know the "lean/rich" fuel ratio throughout the run, otherwise you are just shooting in the dark.
You'll get there but, it'll take 10 times longer; maybe 20 times longer.
Post  richter69 July 6th 2010, 7:04 pm
drag it down here............I got lots of alky tunin' stuff. Very Happy
Post  342g July 6th 2010, 9:54 pm
Wow, thats a fur piece, what about we mee in St. LOUIE. Very Happy Very Happy
342g
342g
Post  bbf-falcon July 7th 2010, 6:55 am
Wait until Norwalk Harold,there will be plenty of Alcoholic's there to get it right.
