stock block limitations
+6
4thHorseman
valleydawg
Northwest outlaw
cooter
10 posters
I am new to this site and am looking through other topics and havent seen an answer to my question that i am sure has been discused to death. What is the hp limitation of a stock 2 bolt 460 block? I am trying to build a 575 hp and 575tq motor which is totaly reliable on the track and street use (mostly street driven) Love the site and am happy to be here!
cooter- Posts : 220
Re: stock block limitations
you will be fine. Some people have push a 2 bolt to the 1000+ mark
Northwest outlaw- Posts : 962
cooter wrote:I am new to this site and am looking through other topics and havent seen an answer to my question that i am sure has been discused to death. What is the hp limitation of a stock 2 bolt 460 block? I am trying to build a 575 hp and 575tq motor which is totaly reliable on the track and street use (mostly street driven) Love the site and am happy to be here!
That would be a mild 385 series engine.
750hp is a general safe limit for 2 bolt blocks with proper parts and good tuning skills. They have been used sucessfully in much higher hp builds, But IMO your over the realistic pratical safe limit at 750......
You will be fine with a 600 hp engine and it should last forever!
valleydawg- Posts : 427
thanx everyone, i am being told by my machinist to buy a new 4 bolt block but i would rather spend the money on better pistons, crank and rods if i dont have to put it into a new block.
cooter- Posts : 220
At the level your wanting the factory block is fine..... your machinest must be a Chevy Guy?
Spend the money on H beam Rods and a good set of pistons. Ford also has a great deal on aluminum SCJ heads right now, contact Lem Evans.
are the scj heads a good head for making 600 hp? I need a head with good low end torque
cooter- Posts : 220
yes, they will make your goals fine and are priced right.
My car has ran 7.70's @ 175+mph...on a stock block.
The BBF stock block is a bit of a hoss. It can take a bunch thrown at it with a solid tune. I'd agree to 750-800hp on a 2 bolt. This ain't no BBC here.
With any reputable BBF aftermarket head and a fairly mild valvetrain combo you should hit 575hp/tq like throwing a stick at a wall. Have the guys on this site critique your combo for you to dial it right in and set you up with the best deals before you spend the bucks. SCJ's would definately get you there and then plenty with the right combo, as would TFS streets and probably a number of stocker head castings which were shown some loving.
Good luck!
Good luck!
4thHorseman- Posts : 400
cooter wrote:thanx everyone, i am being told by my machinist to buy a new 4 bolt block but i would rather spend the money on better pistons, crank and rods if i dont have to put it into a new block.
Sounds like your machinist is trying to make a quick buck selling you something you don't need, JMHO. Or he doesn't know about Fords...
torkair- Posts : 404
cooter wrote:are the scj heads a good head for making 600 hp? I need a head with good low end torque
What are you planning to stick this engine into? What trans, rear end gearing, and rear tire height? Is this going to be a daily driver, or a sunny Sunday cruiser? When you say totally reliable, how many miles do you want to go before having to do a "freshen up". Is there a reason for the "575 hp" requirement?
Dave
DJOHAGIN- Posts : 91
Spend the money you save on a good mackinest, sounds like the one you have don't know how to build a ford, there is a boat full of guys, that say they are engine builders, but they can't build a big block ford, don't ask me how I know.
342g- BBF CONTRIBUTOR
my machinist is very good but he likes to overkill things to prevent problems. He doesnt sell me the parts he just tells me what he thinks i require. I am building a 1962 unibody 1/2 ton pro street truck which i want to take on the HOTROD POWERTOUR in 2 years. 575 hp is a rough estimate of what i am aiming for but lots of torque is the requirement for this heavy truck. I havent picked a tranny yet but a c6 is probable, 18.5 x 33 tires with about a 411 gear
cooter- Posts : 220
If tq is what you are mostly after, I'd drop in a good Scat 4.3" crank and bump in up in cubes. Not much cost for a lot of gain. I'd do a forged unit, easier/cheaper to balance, and definately able to handle more if you ever decide to up the power level.
schmitty- Posts : 4538
» Stock 3.850 crankshaft limitations
» bought a block off the machine shop a guy backed out of , wondering my limitations
» question about stock 1971 stock block
» Differences between stock type block and the a460 block?
» stock block
» stock block
