i need help finding the best 460 block
DanH
96Mustang460cid
bb429power
bigmichael1
Page 1 of 2
Page 1 of 2 • 1, 2
hi all i need help i want to build my frist drag car i doing it with my kids i want to do a 95 towncar i going to go with a big block more for the low end tork to get it moveing any way i looking at the 460 big block just woundering what the best year block to go with i can get one out of a 92 E450 van will this be a ok block or shoud i go with a older motor from the 60's to 70's block or is there any diff between them thank
mike from wisconsin sorry about my spelling
bigmichael1- Posts : 2
Re: i need help finding the best 460 block
The older ones like the 60's and 70's are better. They are internally balanced and they are more quality made casts. Also, the newer blocks have the cylinders extended into the crankcase more so that's a downfall. It takes away from its stroking capabillities, unless you want to machine it. Look for an early block and if you can get a cj or scj block. They have thicker main webs.
I'll let the hero get his cape on, Fabio (richter69) will be here before you know it to answer all your questions and then some. He's the BIG DOG of the forum.
bb429power- Posts : 3129
1st what kind of HP and what rpms you plaining on running any 460 will do just depend on what you are going to build
bb429power wrote:The older ones like the 60's and 70's are better. They are internally balanced and they are more quality made casts. Also, the newer blocks have the cylinders extended into the crankcase more so that's a downfall. It takes away from its stroking capabillities, unless you want to machine it. Look for an early block and if you can get a cj or scj block. They have thicker main webs.
I highly doubt I'm the, "BIG DOG" you referenced, but I'll chime in anyways.
Even with the newer blocks (D9TE), you can go with a 4.5" stroke without grinding...so I don't think the longer cylinders are a downfall. In fact, for a stroker application, most would see it as being advantageous (some may argue how 'large' of an advantage though).
Also, I don't think the older blocks are higher quality castings. A block summit a few years ago, if I remember right, shown no specific casting as being predisposed to thicker cylinder walls (I'm not sure about the CJ and SCJ).
I'm sure others will chime in. Maybe, if I'm lucky, I'll get to see the "BIG DOG" put his $0.04 on the subject .
Have a good day!
Michael
96Mustang460cid- Posts : 154
Well I have a 71 block and when I would tell someone (they were all BBF experts) the year of it. They would tell me it was a good block, they said the earlier years are better because they were made before Ford started cheaping out and mixing nickle in with the cast. I could be wrong but that's where I got the idea from.96Mustang460cid wrote:bb429power wrote:The older ones like the 60's and 70's are better. They are internally balanced and they are more quality made casts. Also, the newer blocks have the cylinders extended into the crankcase more so that's a downfall. It takes away from its stroking capabillities, unless you want to machine it. Look for an early block and if you can get a cj or scj block. They have thicker main webs.
Have a good day!
Michael
And I called him the "BIG DOG" because everyone seems to idolize him as the best racer on here. I guess he's the expert, he is a A+ know it all racer from what I have seen and heard.
bb429power wrote:Well I have a 71 block and when I would tell someone (they were all BBF experts) the year of it. They would tell me it was a good block, they said the earlier years are better because they were made before Ford started cheaping out and mixing nickle in with the cast. I could be wrong but that's where I got the idea from.
Actually, nickel would normally be a positive in that application;). You might find this thread interesting:
http://www.460ford.com/forum/showthread.php?t=146739&highlight=nickel
I was just poking fun at Jon with ya .
Have a good day!
Michael
bb429power wrote:And I called him the "BIG DOG" because everyone seems to idolize him as the best racer on here. I guess he's the expert, he is a A+ know it all racer from what I have seen and heard.
Also, I wouldn't give him too much credit...mainly, he just talks a lot a !hit to people . Okay, that's all the !hit talking I'm doing for this month!
Have a good day!
Michael
bb429power , don't know where you get this info , but should do more reading in the tech-- on the forums that posting .
DanH- Posts : 1081
That's one of the things I learned from word of mouth. Like I said, I was told those things. But I read a million things about engines mainly BBF's so I do know my way around for the majority of things. I hear ya 96mustang I'll read up on that also. The information I got about the longer cylinders and not being able to stroke it as much I got from another forum. It seems like the ONLY things I learn from other people except from on here ends up being wrong. Or so I am told by the people on here which they are usually right.
Big Daddy AC here, and Michael Dunn is correct. The factory blocks are equally capable. The BOSS and 4 bolt SCJ stuff being more desirable for their 4 bolt mains. I am using a D9TE block and had no trouble installing my 4.5" crank. A problem can arrise when trying to install an early internal balance crank into a later model block. Always check clearances.
schmitty- Posts : 4538
If the 92 block is priced right, it's as good as any other non boss or non scj block. They do have longer cylinders and external balance, plus the early internal factory cranks will not fit without alot of grinding.
The higher nickle thing is total bs urban legand.
The early dove blocks, (read some 429 cj & PI and all scj's) had 4 bolt mains, all outers and most cj's had 2 bolt mains, these blocks are the easiest to convert to 4 bolt mAins due to the bulkheads / rails being conpletly flat.
2 bolt blocks are pretty safe to 750 hp and have been used at much greater levels.
If you go to Proven Builds and look at the block sticky it will lay it out for ya.
514Fox87- Posts : 436
Down side to the 92 motor is the heads, the are unique to the 460 efi motor and intakes and headers do not interchange with stuff produced for early / carb'd 429/460's. Their are no intake avaliable for the efi heads.
They work well but its the parts avalibility that's keeps them from being used in most performance applications.
I knew that, but that's why I figured you couldn't stroke it as much because I figured the throws o a larger crank would be out farther. Never assume! That's the lesson.schmitty wrote:Big Daddy AC here, and Michael Dunn is correct. The factory blocks are equally capable. The BOSS and 4 bolt SCJ stuff being more desirable for their 4 bolt mains. I am using a D9TE block and had no trouble installing my 4.5" crank. A problem can arrise when trying to install an early internal balance crank into a later model block. Always check clearances.
I hate when someone tells you something and you thank them and think "they really helped me out there and they really tought me something too" and then you find out its complete BS.
Well I know about the newer heads in comparison to the older ones as in D3VE vs. D0VE and how they flow different and what each is better for.
Thanks for helping me teaching me something in the process, I'll be told I know a lot then this crap happens. Even stuff I read in books can turn out wrong, I guess like I've said before. It the experience that's got me down, that's where you learn most of it.
Justin, don't sweat it, you are in the house of honest knowledge here.
I looked up in the sky and the beacon was a shinin'...........hung up my red phone with Lem, grabbed my cape....and here I am................ ..................
Fabio the A + know-it-all racer slash HeRo at your service..............
We really do need to get this guy a beacon.richter69 wrote:I looked up in the sky and the beacon was a shinin'...........hung up my red phone with Lem, grabbed my cape....and here I am................ ..................
Big Daddy, I can bearly say that without cracking a smile. Well I have realized quickly that people here usually give you great knowledge and go out of their way to help you. I just wish I could return the favor, and no not like that fabio. I know how your mind can wander.
bb429power wrote:We need to buy this guy a sky light. Shine it in the sky and he'll know that someone needs his help.richter69 wrote:I looked up in the sky and the beacon was a shinin'...........hung up my red phone with Lem, grabbed my cape....and here I am................ ..................
Schmitty is "Big Daddy"...............
That's who I was talking to for the second part. By the way, I wasn't here when you named him that. So whats the story behind that one? Why'd ya name him big daddy?
Blake is "The Snake"
Coug is................well.............. the Coug
KY Jelly is "KY mustang" aka "pearl necklace"
56tbird is "the King" ....or sometimes refered to as "the mullet"
bb429power wrote:That's who I was talking to for the second part. By the way, I wasn't here when you named him that. So whats the story behind that one? Why'd ya name him big daddy?
devildog named him that, I took it to the next level................
Oh yeah that's right, can't be official without HeRo approval. Admin approval means nothing, the HeRo's run the show around here.richter69 wrote:devildog named him that, I took it to the next level................
I thought Chuck was the mullet. Thanks for the rundown, I just heard the Coug was named the C.O.P of the Buy Sell Trade. I'm gonna be lonely when I'm 50-60 some years old on here and none of you guys are around anymore.
richter69 wrote:bb429power wrote:We need to buy this guy a sky light. Shine it in the sky and he'll know that someone needs his help.richter69 wrote:I looked up in the sky and the beacon was a shinin'...........hung up my red phone with Lem, grabbed my cape....and here I am................ ..................
And Fabio is HeRo. HeRo is a real cool dude. How come. HeRo gets a cape and red phone and Big Daddy don't?
Stop whining, you got the name that every single one of us has been waiting to get. I don't have a nickname, except for in auto I was called "the coon".
Page 1 of 2 • 1, 2
» Need help finding correct oil pump pick up tube
» Finding the right 460 that I can work on for my F100
» Finding True tdc the easy way
» trouble finding starter to fit 429scj with m/t
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
Page 1 of 2
