Guys help me please..
Most of ya'll now me or recognize me for hanging around. I'm trying to get my cougar to run mid 11's and I havent had a lot of luck yet in fact I would say I am the slowest guy on here for what I have.. Here is my build, ya'll tell my what I might do diff. I have some PI heads Im gonna have Blake look at and I also have a torker II that I could use.
1969 cougar 3650lbs with me in it
456 gears
goood converter
429 w/wiesco dome pistons
h beam rods
640/640 .258/.260 solid cam
stealth intake/850 holley
procomp heads....
et streets
12.31 fastest/ 12.40ish normal I have a smaller cam .248/.258 588/600 solid crower bacicaly same as the cam lem is selling for 99.00 but its a solid
456 gears
goood converter
h beam rods
procomp heads....
et streets
cheatham- Posts : 267
Re: Guys help me please..
Shane, did you get some slapper bars or anything yet? I'd be glad to meet you down at the valley and help you tune on it (I'll leave my car at home lol)
I've got some carbs here to try, but they all burn the wrong flavor of fuel.
I would stick the T2 deal on it, I also have a variety of spacers we can try.
No slapper bars yet... I do have an old set that I didnt think worked ..hummm I will put the T2 on this week if the weather and things hold up I was going to go try it again on th 4 or 5 of september
Less gear, have Blake rub on the PI heads and look at some different cam options.
What convertor? What mph? What kinda rpm you spinning it to? Over the stripe?
Its one of UCC's 9" converters.
You still got that stroker crank Shane???
107 is about it as far as mph but each time I go out I find a little more I'm spinning it to 6600 or a tick more
sometimes 6200 over the stripe I dont remember but will watch that next outing. Every time I go out lately I only get to run 2 times wife has to go home or some other stuff happends I think if I could get some help tunning and some seat time it might pick up more
I need to go test some myself, but could put it aside to go help you. That weekend looks ok for me, of course it would need to be TV.
The kid might bring the Chevy truck too, he made some 1/8th mile laps at Lawton but I want to run it in the 1/4 just too see..............
This weekend looks like crap for weather, get the manifold on it and I'll see if I can dig up a gas carb........unless you want to try some alky
I'd get some kind of traction device on it, hell even those 19.95 bolt on slapper bars would be better than nothing................... with just the leafs i'm afraid your gonna hurt some drvieline parts.
Heads should help alot. Plus some additional tuning.
agreed...........
After Blake puts the magic on them PI's, put some stroke in that deal and you'll be asking how to slow it down to run 11's.
Is this a race only car or race/street?
-> Need 60 foot info.. <-
1. What fuel pump ya got and the fuel line size?
2. Could you add the spring rate that is up front and the type of shock?
Q's 1 & 2 are for information purposes.. I don't know your car setup.
My old Mach1 ran 12.5 @ 107 with the following:
466 Flat top piston
D3 heads with home porting stock valves and rockers
Summit cam 214/228 @ .503
Stealth Intake
850 Holley vac secondary
Stock exhaust manifold Cast Iron
2 1/2 exhaust no X pipe
3:50 gears
C-6 trans with stock converter
DR Tires 275-60-15 28 dia
Car weight on truck scale = 3420 lbs
Leaf spring 60 foot was 2.10 and worse
I put up the above info to maybe compair what you have?
466 Flat top piston
Stealth Intake
3:50 gears
westsideford- Posts : 398
richter69 wrote:I'd get some kind of traction device on it, hell even those 19.95 bolt on slapper bars would be better than nothing................... with just the leafs i'm afraid your gonna hurt some drvieline parts.
Listen to Jon. Last thing you want to do is tear up something because you don't have some kind of traction device to keep the pinion, leafspring, & housing rotation in check. At the very least you need some kind of slapper bar & a few braces welded the the back side of the spring pearches to box them so they don't try to fold/roll over if the car hooks hard.
DILLIGASDAVE- Posts : 2262
.....and put those front Koni shocks on it you got from me a few years back lol.
» what do you guys think?
» why am i being deleted
» THANKS to all you guys for your help
» Hey FE Guys
» What is the most preferred distributor (type) for street use? 545 stroker build-up
» Hey FE Guys
