Oil Hole sizing ( bushed lifter )
Oil Hole sizing ( bushed lifter ) Empty Oil Hole sizing ( bushed lifter )
Post  RGL July 27th 2010, 11:26 pm
first , let me thank the guy who furnished the 460 blueprints, they were of much help. next question i have for some long time BB engine guys, what size to make the oil hole in the bushing, here are related info
A460 block with .082" restrictor in lifter galley.
crane lifters
dry sump oiling - 15" vacuum
I do not want to restrict anymore oil with the bushing, just supply the lifters, and enough oil to keep pushrods happy , and big triple springs alive . I have scavenges in the head pulling oil out . With hot oil ( 175 deg ish) , I have about # 68-70 at WOT , and 55 psi at idle ( pump is driven @ 80%) . I am happy with those numbers, but dont need to loose any oil pressure. It leaves me wondering what size oil hole to drill now, i am thinking somewhere in the 0.080-.125" range . My lifter clearance was excessive on one side before, the bushings should tightne this up to normal specs.
thanks for any future input.
RGL
RGL
Oil Hole sizing ( bushed lifter ) Empty Re: Oil Hole sizing ( bushed lifter )
Post  rmcomprandy July 28th 2010, 10:25 am
.062" in each one will be fine.
Post  res0rli9 July 28th 2010, 10:58 am
I have a block that already has the bushings in it, how do I check the size of the hole ?
Post  dfree383 July 28th 2010, 11:12 am
res0rli9 wrote:I have a block that already has the bushings in it, how do I check the size of the hole ?
Real careful... Laughing I'd think on could take some wire of known dia. and insert it?
Post  RGL July 29th 2010, 2:37 am
thanks
RGL
RGL
