Looking to build a serious strip car will this block work for me?
Wayne Pearce
Treeyasoon
blown460
im gonna be building a strip car and plan on stroking a 460 and adding either dual tunnel ram,procharger f1 or f2 or maybe a 671 blower of some sort? wandering if this block would hold all the power i need? also what power adder u reccomend?
http://www.eliminatorproducts.com/product/18.aspx
blown460- Posts : 8
Re: Looking to build a serious strip car will this block work for me?
That block is only a 2-bolt main....You are gonna' want a 4-bolt if you are gonna' run a power adder.
Treeyasoon- Posts : 759
If you're going to build a serious strip engine, you need to start with at the very least, the "sportsman" block, or a Ford A460 block. Both of these blocks have four bolt mains on 2, 3, and 4 to handle all that "horse pressure". I'm thinking you want to minimize your costs, but I wouldn't cheap out on the block anymore than I would on the rotating assembly. Just my 2 cents.
Wayne (SAWDOFF) Pearce
Wayne Pearce- Posts : 658
looks like nothing more than a newer version of a dove-a block to me... not sure on the oiling system though as there are no specs. for the power you are making as stated above a better block would be a wise choice. I also compared the sportsman (eliminator) to the Ford A460 and the Ford is able to go .100 bigger bore wise, and has Siamese cylinder bores (no water jackets around the cylinders) and is 18 bolt capable (heads)...and is close to 100 dollars cheaper as well... I went with an A460 Ford
http://bfevansraceparts.com/FordRacing.aspx
138- Posts : 1593
I believe that block is from their industrial side of the business. If Chuck Stevens sees this I'm sure he could verify that.
Also looks like they just don't drill it for the outer bolts.
"They", ELIMINATOR, has not sent me any info on their a-460 block. It sounds similar to the SPORTSMAN block, without the 4 bolt caps,for a bunch less money.
If that's a picture of the actual block, it looks easy enough to convert to 4 bolts. Could be a good option for a racer on a budget who would like something better than a stock block. The price is right.
BradB- Posts : 43
» will tfs A460 heads work on my d1ve block ? or do they only work on the race blocks
» 521 STREET/ STRIP BUILD
» first big block build
