Let the 466 mayhem begin...
+22
dirt_worker
1970 ford maverick
nuclearcobra
56Tbird
501ranger
Tony M
audietorino72
72mav
blown86hallet
lghting94
Maddmattmustangs
ThndrChkn
bb429power
26 posters
Page 6 of 7 Previous  1, 2, 3, 4, 5, 6, 7  Next
Let the 466 mayhem begin... - Page 6 Empty Re: Let the 466 mayhem begin...
Post  res0rli9 September 3rd 2011, 6:55 pm
The converter goes in twice and if it wasn't all the way in and you tightened the trans down tight you have broke the front pump??
some times you have to spend the c/v a lot.
Post  bb429power September 3rd 2011, 7:44 pm
res0rli9 wrote:The converter goes in twice and if it wasn't all the way in and you tightened the trans down tight you have broke the front pump??
That actually happened to my brothers bronco. But they didn't spin the converter on I guess...I didn't do any of the work. And it popped farther onto the shaft a good three times when I spun it on.
bb429power
bb429power
Post  bb429power July 26th 2012, 12:20 am
Dang its been a while... I've had this thing running, I just haven't been on here in the longest time. I need to cut my bed floor out and tub it with an all new sheetmetal floor (if you have any ideas or suggestions let me know please), still coming up with ideas. Then I will know what tires and rims I can fit. Also need to run the brake lines.
https://www.youtube.com/watch?v=LdajtXm8yhI&feature=channel&list=UL
bb429power
bb429power
Post  69F100 July 26th 2012, 12:41 am
about time you fire it up Laughing
Post  bb429power July 26th 2012, 12:47 am
Its been running for a while, just haven't been on here to talk about it hahaha.
bb429power
bb429power
Post  bruno July 26th 2012, 6:55 am
great job justin, sounds good
http://WWW.CKRME.COM
Post  bb429power July 26th 2012, 10:01 am
Thank you, and also, thank you for that balancer you gave me a while back
bb429power
bb429power
Post  bb429power March 11th 2013, 1:21 am
Driven it a few times, needs rear shocks, a few extra bolts, and I have to mount my 5 point harness. I'm scheduled to align the front end this Friday, not sure how that will go since its 2wd I beams with kingpins. I've done some newer stuff though. Only issue I'm having is the front brakes don't want to release, I fixed it but it's back. Not sure what it is yet.
Let the 466 mayhem begin... - Page 6 2013-03-10_17-53-07_874_zps6cf40f0b
Let the 466 mayhem begin... - Page 6 2013-03-10_16-31-26_619_zps48ec0eac
Let the 466 mayhem begin... - Page 6 2013-03-10_16-31-38_19_zpsbeee4127
bb429power
bb429power
Let the 466 mayhem begin... - Page 6 Empty LET THE MAYHEM BEGINE
Post  1970 ford maverick March 11th 2013, 9:06 am
[quote="bb429power"]Driven it a few times, needs rear shocks, a few extra bolts, and I have to mount my 5 point harness. I'm scheduled to align the front end this Friday, not sure how that will go since its 2wd I beams with kingpins. I've done some newer stuff though. Only issue I'm having is the front brakes don't want to release, I fixed it but it's back. Not sure what it is yet. [quote] Did you replace the rubber lines from the wheel cylinders to the hard lines on the frame ?,those will collapse when you press the brake and it will take afew minutes before they will release if everything else has been replaced . Hope this helps,MavMan
Last edited by 1970 ford maverick on March 11th 2013, 9:10 am; edited 1 time in total (Reason for editing : mistake)
1970 ford maverick
1970 ford maverick
Post  dirt_worker March 11th 2013, 9:24 am
Looks good justin.
can you explain your comment on not being sure how the alignment will go because the I beams are 2wd?
Looks like the camber is off from your photo. (Top of the tire leaned out)
dirt_worker
dirt_worker
Post  bb429power March 11th 2013, 11:50 am
Literally everything, lines, hoses, wheel cylinders, master cylinder, calipers, rotors, pads, are new minus the combination valve. That's the only thing I didn't get new, everything else is new including the metering block on the axle.
As far as alignment, it's way off. Looking straight on you can see it even more, it has a ton of positive camber. (not sure why). I see a lot of people saying that they have to bend the i beams, but I think there should be another way.
bb429power
bb429power
Post  dirt_worker March 11th 2013, 12:20 pm
The spring length is the only other way to adj the camber on these. Change to softer springs, cut a coil off or heat em u up to lower it down and bring the camber closer to neutral.
I've aligned mine myself more than once, but I had the tubular dropped I beams that you cannot adj the caster on..only toe in and camber...
dirt_worker
dirt_worker
Post  dirt_worker March 11th 2013, 12:24 pm
Looks like it has the wrong spring in it too me...
Make sure you have a 1/2 ton V-8 spring in there before you modify the current springs...
dirt_worker
dirt_worker
Post  bb429power March 11th 2013, 12:36 pm
dirt_worker wrote:Looks like it has the wrong spring in it too me...
It was fine before the restoration, with the same engine and trans. I never took them out though so I don't see why they changed, maybe I lost a lot of weight? I'll try to find an old picture of it to double check.
bb429power
bb429power
Post  dirt_worker March 12th 2013, 11:11 pm
can you post a better picture of your front suspension...something must be amiss?
dirt_worker
dirt_worker
Post  bb429power March 12th 2013, 11:22 pm
Sure thing, and maybe it just needs to be driven a bit more to settle in? Or... crap, when I swapped to disk brakes, the rotors sat back farther than the drums by a lot. Maybe because they are further in it's screwing with the geometry? I bet that did it... Mad
Let the 466 mayhem begin... - Page 6 2013-03-10_16-37-46_925_zps77253944
Let the 466 mayhem begin... - Page 6 2013-03-10_16-34-24_127_zps0ff2056c
Let the 466 mayhem begin... - Page 6 2013-03-10_17-53-19_564_zps68290499
bb429power
bb429power
Post  dirt_worker March 12th 2013, 11:46 pm
what did the brakes come off...curious? Mine were off a 78f100 and my calipers were mounted on the rear of the rotor.
the twin i beams do need to settle in some but if you rolled in front and back or drove it any it should be already settled. wonder if the ibeams are meant for a left and right?
dirt_worker
dirt_worker
Post  69F100 March 12th 2013, 11:55 pm
dirt_worker wrote:what did the brakes come off...curious? Mine were off a 78f100 and my calipers were mounted on the rear of the rotor.
X2 my calipers are in the rear and not in the front mine came out of a 74 f100 yes they are a right and left on the I-beam if my memory serves me correct been 15 or 16 years ago when I done mine so I might be wrong scratch
Post  bb429power March 12th 2013, 11:57 pm
I couldn't find any of those spindles and I needed to convert everything to the 5x4.5 pattern. So I used some brainpower, looked up different parts, mocked stuff up, custom made the setup myself. The rotors and bearings are for a 80 f100 with 5.4.5 lug pattern, the seal is the same as my original 67 drum setup, the calipers and lines are for a (I know) chebby suburban. The mounting brackets are custom made by me. Drilled and tapped it all. I knew they could be mounted on the front because that is how the 60's f250 disk brakes mounted up. Oh and they are the stock drum brake spindles.
So yeah, it's a whole lot of different stuff but you gotta give me some credit for figuring that all out myself Very Happy only thing I didn't figure out myself was that the 80 f100 rotors had a 5x4.5 lug pattern. But no one told me I could make em work on these spindles.
Ps: I want to be a chassis fabricator or engine builder Laughing
bb429power
bb429power
Post  69F100 March 13th 2013, 12:10 am
bb429power wrote:I couldn't find any of those spindles and I needed to convert everything to the 5x4.5 pattern. So I used some brainpower, looked up different parts, mocked stuff up, custom made the setup myself. The rotors and bearings are for a 80 f100 with 5.4.5 lug pattern, the seal is the same as my original 67 drum setup, the calipers and lines are for a (I know) chebby suburban. The mounting brackets are custom made by me. Drilled and tapped it all. I knew they could be mounted on the front because that is how the 60's f250 disk brakes mounted up. Oh and they are the stock drum brake spindles.
Their your problem that chevy stuff one a ford affraid lol!
Post  bb429power March 13th 2013, 12:13 am
I know, when they were locked up I told my buddy "she's just mad at me right now for using chevy stuff on her" Laughing But I found out from the parts store that those calipers are actually used on a lot of things. Like jeeps even. I just used them because of the way they tighten down and I was able to make a plate for them.
bb429power
bb429power
Post  Tony M March 13th 2013, 5:21 pm
Truck looks great ! Cant wait to see the finished product.
Tony M
Tony M
Post  bb429power March 13th 2013, 7:06 pm
Thank you Very Happy My hopes are to race it at my usual race which is April 27th this year. I figured I would debut it there, or race the maverick which also has a new setup. I wanna race both! Laughing
bb429power
bb429power
Post  bb429power March 19th 2013, 8:36 pm
The toe was way off, causing the camber to go out of whack when I rolled it. It's fixed, now I'm working on lowering it.
bb429power
bb429power
Post  bb429power March 29th 2013, 10:34 pm
So I blead the brakes with the disk master cylinder today, everything works just peachy
And the pedal is a whole lot stiffer than before also requiring less travel to get tight
FINALLY!!! Laughing
bb429power
bb429power
