Are you guys bracing or adding cable to front of motor to frame?
Treeyasoon
Ed501
I have a aftermarket k-member and the factory trans crossmember and beleive if i wheels up very high that i should help retain engine position and help it not to flex back toward firewall. If it goes really high up there thats alot stress on solid motor mounts. I could add an aluminum torque plate on sides of heads which would help also. This is a aluminum headed 501 but still heavy in my book. Thanks.., ED
Ed501- Posts : 139
Re: Are you guys bracing or adding cable to front of motor to frame?
if you have solid engine mounts why worry?
the Coug- Posts : 3055
Overkill is not a bad thing in a race car but, I agree with Randy....The solid mounts should suffice except perhaps under extreme conditions...
Treeyasoon- Posts : 759
Okay, cool.,, Ihave seen a car like that and thought the tubular k and stands could use some support with tires up. I guess as long as drivshaft doesnt bottom out you should be okay. I am just trying to be sure i am ready to take it to track. These are torque monster for sure. Lets see some low 80 degrees and TRACK HERE I COME lol, Thanks...,ED
Ed501- Posts : 139
I have seen lots of these cars come down hard and I have never seen one flex enough to cause any problems. the caster camber plates will bend first.
whatbumper- Posts : 3024
just think of the strain the solid mounts put on the block.
I am plan on running some sort of torque strap to take some load off the block. Waiting to put on alt. then see what room i have on both sides. ED
Ed501- Posts : 139
whatbumper wrote:I have seen lots of these cars come down hard and I have never seen one flex enough to cause any problems. the caster camber plates will bend first.
I can prove that
If you feel the need, you can always install engine limiters and then go ahead and install some engine plates to do away with the solid mounts that ALWAYS seem to be in the way
D. Sea- Posts : 2768
THATS WHY i make,use,and sell bb ford foxbody engine plates, not in the way,and you can bolt things to them,D. Sea wrote:whatbumper wrote:I have seen lots of these cars come down hard and I have never seen one flex enough to cause any problems. the caster camber plates will bend first.
I can prove that
BOSS 429- Posts : 2372
BOSS 429 wrote:THATS WHY i make,use,and sell bb ford foxbody engine plates, not in the way,and you can bolt things to them,D. Sea wrote:whatbumper wrote:I have seen lots of these cars come down hard and I have never seen one flex enough to cause any problems. the caster camber plates will bend first.
I can prove that
Yep, I agree
I was mainly concerned with rear movement since the trans has a urethane, mount and the weak factory crossmember design. Didnt want flexng then the crack later developing on tubulat k. I guess i just a little leary of a tubular k, ITs a PA so it should be strong as any. Thanks..., ED
Ed501- Posts : 139
dont worry about that stock crossmember, we ran mid 8's 160 mph plus 1.2 60s on one for years, carrying the hoops, nothing wrong, or weak about it
-RICH
-RICH
» does anyone make motor mounts to put a 460 in a ranger frame???
» main girdle
» Belt drive shutoff cable, shut off cable, BG bypass regulator
» ok truck guys i need advice come on in heros need motor advice also
» Throttle Cable and Kickdown Cable Questions
» main girdle
