C-HEADED MANIFOLD DISTRIBUTOR ?
+9
Wheelie58
138
fatal addiction
bb429power
badnotch
13 posters
Page 2 of 2 Previous  1, 2
C-HEADED MANIFOLD DISTRIBUTOR ? - Page 2 Empty Re: C-HEADED MANIFOLD DISTRIBUTOR ?
Post  badnotch August 23rd 2010, 8:50 pm
not sure on avalability havent called them yet
badnotch
badnotch
http://www.gnlmotorsports.com
Post  badnotch August 23rd 2010, 8:51 pm
just sent e-mail
badnotch
badnotch
Post  Lem Evans August 23rd 2010, 9:06 pm
Lem Evans wrote:MSD PN8580.........lite silver springs and black bushing.
Post  badnotch August 23rd 2010, 9:13 pm
isnt the 8377 a crank trigger dizzy ?
badnotch
badnotch
Post  Lem Evans August 23rd 2010, 9:19 pm
badnotch wrote:isnt the 8377 a crank trigger dizzy ?
I give...is it ? What makes you think you need one?
Post  Doug Rahn August 24th 2010, 1:02 am
Uhhhhh.........isn't that what you wanted, a taller crank trigger distributor? According to a MSD Tech on the MSD forum, the measurement from where it sits in the block to the bottom of the housing is 4.35".
Post  badnotch August 24th 2010, 5:09 am
i need a tall one -thats all not sure on if the 8580 ? never gutted a dzzy before that all what ever you guys say works im game with that other place doesnt stock the 8377 they mailed me and said they didnt have any 8377
badnotch
badnotch
Post  bbf-falcon August 24th 2010, 7:06 am
Gerry,
When you gut one for a crank trigger,all that is used is the rotary button to distribute the fire to each wire. Just needs the advance locked all the way.
Post  DanH August 24th 2010, 8:37 am
to lock out a msd, remove spring/weights &bushings. remove advance limit bushing (under weight plae. remove roll pin in collar , pull up center shaft and rotate 180* . push shaft down and replace collar/pin leave pickup in dist. bag the other parts to convert back when/if need
DanH
Post  badnotch August 24th 2010, 12:18 pm
Thanks guys
badnotch
badnotch
Post  badnotch August 24th 2010, 6:01 pm
any body happen to know part number on the dizzy i have short one
badnotch
badnotch
Post  BOSS 429 August 24th 2010, 11:17 pm
badnotch wrote:ive got the short distrib,and it doesnt clear .do i have to buy a new one that is taller or do they make a different bottum and top cap that is smaller ? thanks
or i will modify the manifold to make it fit Smile im a welder by trade so cutting and welding is as easy as pie -but if i dont have to i wont
thanks
C-HEADED MANIFOLD DISTRIBUTOR ? - Page 2 Droidpics126
we use a 8580 with a c intake
Post  BOSS 429 August 24th 2010, 11:19 pm
bbf-falcon wrote:Gerry,
i dont fool around i just tac weld the top so it can not move,
