Max hp before it breaks
Max hp before it breaks Empty Max hp before it breaks
Post  466coupe August 26th 2009, 1:04 am
I have a 70 lincoln block, what is the max hp i can get out of this? Ive heard several different #s
466coupe
Max hp before it breaks Empty Re: Max hp before it breaks
Post  somethingclever August 26th 2009, 4:39 am
Anywhere from 750-1500.
In other words...it depends.
somethingclever
Post  dfree383 August 26th 2009, 6:47 am
And a poor tune or poor build can break one at less than 400.....
IMO 750 is a good safe limit for a 2 bolt block N/A tuned properly, to 950 you'll need 4 bolt caps and a fill is a good idea... Above that an after market block is suggested, but stock ones have been used above this level successfuly.... Its all in how lucky you feel and you abilities as a engine builder / tuner.
Post  466coupe August 26th 2009, 7:51 am
Is the same for blower or turbo, i have been reading guys making 1000 at the wheels easy. Am i misunderstanding or misinformed?
466coupe
Post  96Mustang460cid August 26th 2009, 8:05 am
466coupe wrote:Is the same for blower or turbo, i have been reading guys making 1000 at the wheels easy. Am i misunderstanding or misinformed?
Turbo's are supposed to be easier on parts when tuned properly. But, a turbo engine with a 'slightly-off' tune can cause damage very quickly. So, the tuning window isn't as forgiving.
Have a good day!
Michael
96Mustang460cid
96Mustang460cid
Post  466coupe August 27th 2009, 12:19 am
What about these 900 hp pump gas motors?
466coupe
Post  dfree383 August 27th 2009, 6:17 am
Which ones are you refering too?
