help with f-350 breaks
I have a 1994 f-350
how do you keep the calipers from sticking
Unfortunatly the truck sits a lot
Thanks Rick
Thanks Rick
rck532- BBF CONTRIBUTOR
Re: help with f-350 breaks
For a vehicle that does more sitting than running I use silicone brake fluid.
It isn't hygroscopic, As in it doesn't absorb water, which is probably your
problem...
problem...
canzus- Posts : 28
Antiseize on the hardware too....
Clean and grease the caliper slide pins if it has them...
jbozzelle- Posts : 3705
