holley black copy loosing psi and not pumping ?
+11
95lightiningguy
torkair
TorinoGT
89lxcoupe
15 posters
holley black copy loosing psi and not pumping ? Empty holley black copy loosing psi and not pumping ?
Post  89lxcoupe August 22nd 2010, 9:29 pm
its the pro comp 14 psi pump, same as the holley black. hey guys i have had this problem for a few weeks, i don't have the car drivable but just by starting it, it will hold 6 psi then a few minutes later it will loose psi and quit pumping ? the filter before the pump will be full and the filter before the carb will still have some fuel in it. the pump had a small leak so i put a new gasket on it and thought i had fixed it but it still has a small leak ? i am running out of options and need some fresh ideas. i do have another spring and relief valve i could put in it ! any ideas.....
89lxcoupe
holley black copy loosing psi and not pumping ? Empty Re: holley black copy loosing psi and not pumping ?
Post  Nevs August 22nd 2010, 9:43 pm
Well, it might look like a Holley, but it's not. Therein lies your problem. Pro Comp=problems.I'd get a real pump if it was me, but you probably don't want to hear that...Good luck.
Post  TorinoGT August 22nd 2010, 10:12 pm
I dont have any personal experience with ProComp stuff... but I really have yet to hear much good about their products. Prob worth the money time and hassle to just go ahead and buy a new quality pump.
Shane
TorinoGT
TorinoGT
Post  G-Code August 23rd 2010, 12:49 am
89lxcoupe wrote:its the pro comp 14 psi pump, same as the holley black. hey guys i have had this problem for a few weeks, i don't have the car drivable but just by starting it, it will hold 6 psi then a few minutes later it will loose psi and quit pumping ? the filter before the pump will be full and the filter before the carb will still have some fuel in it. the pump had a small leak so i put a new gasket on it and thought i had fixed it but it still has a small leak ? i am running out of options and need some fresh ideas. i do have another spring and relief valve i could put in it ! any ideas.....
" Same as a holley black"
No it's not. It's another piece of shit Pro-Crap knock off sold to people who want to save a buck.
"any ideas"
Yes throw that piece of shit in the trash and buy a decent pump.
G-
Jon
Post  bbf-falcon August 23rd 2010, 8:00 am
Before you throw it away check a few other things.
1.Breather vent to fuel cell could be blocked
2. Fuel line could be crimped somewhere.
If these things happen,it won't make a diff. what pump is on it,it won't hold pressure.
3.Another thing to check would be if the pump pumps good when all other things are shut off(electrically).You always need a relay on your fuel pump.
Good luck Wink
Post  dfree383 August 23rd 2010, 8:33 am
Get a new pump, stay away from the cheap stuff and get a good brand name pump.
Areomotive, Magna fuel, and Holley are a few good names.
Post  the Coug August 23rd 2010, 8:46 am
Isn't it Funny how these people buy this crap to save them money, and by the time they figure out it is Junk they spend more money than they would have if they would have just bought a good one in the first place?
Post  torkair August 23rd 2010, 11:40 am
the Coug wrote:Isn't it Funny how these people buy this crap to save them money, and by the time they figure out it is Junk they spend more money than they would have if they would have just bought a good one in the first place?
Yes it is but in a sad kind of way...
torkair
torkair
Post  G-Code August 23rd 2010, 12:03 pm
Hey I can buy a pump that looks just like a Holley black and save $20.00 wow I think I'll buy 2 of them. Maybe he can get Holley to warranty it for him sense it's just like a Holley black
WTF Razz
Post  89lxcoupe August 23rd 2010, 12:12 pm
WTF Razz
you can't stir up enough shit on 460ford.com so you come over here ? do you feel better now........
89lxcoupe
Post  richter69 August 23rd 2010, 12:13 pm
WTF Razz
your not gonna get any procomp love here either.
Post  89lxcoupe August 23rd 2010, 12:54 pm
funny thing jegs and a few other people have pumps identical to holley ? also the pump works fine outside the car so i suspect its not the pump. thanks for all your none help, i am better off on my own. some of you people have no place saying anything !
89lxcoupe
Post  dfree383 August 23rd 2010, 1:10 pm
Well Thank You.
Didn't you say you have rebuilt it, because it was leaking and its still leaking too???? and where looking for "Fresh" Idea's?
Fresh Idea.......... Pumps Junk, Replace it and blow out your fuel lines and replace the filter........and if you didn't have a filter, better clean the carb out to.
Post  G-Code August 23rd 2010, 1:22 pm
[/quote]
Actually I was here last night I saw it here first.
As far as starting "crap" I wouldn't have touched this thread if the title had read " Pro Comp pump loosing psi" but it didn't did it?
On 460Ford the title is:" Holley Black loosing psi "
Why do you think that is ? why would he not write "Pro Comp loosing psi" ? That's actually a rhetorical question because we all know the answer now don't we.
G- Cool
Post  89lxcoupe August 23rd 2010, 1:39 pm
G- Cool [/quote]
man do what you want to make yourself feel better you wasted your time and mine replying ! and i forgot to put copy ! your to focused on hoping its the pump bad instead of trying to help the problem. the pump works out of the car so its not the pump......... i don't go around bashing people for what parts they use. i had my purpose for buying it and thats none of your business !
89lxcoupe
Post  G-Code August 23rd 2010, 2:48 pm
89lxcoupe wrote:....... i don't go around bashing people for what parts they use. i had my purpose for buying it and thats none of your business !
Curious? Why didn't you list Pro Comp in the title then ? Why did you list Holley, that would seem like a fair question if you ask me.
G-
Post  Nevs August 23rd 2010, 7:13 pm
I'd say when you asked the question on an Internet forum, it did make it our business. Accepting the fact it's not a Holley pump would be a good starting point. If it indeed pumps fine out of the car, then why even ask the question? Your problem obviously lies elsewhere. Your defensiveness speaks volumes in my opinion. But I'm sure you don't want to hear that either.
Post  95lightiningguy August 23rd 2010, 8:46 pm
[img]holley black copy loosing psi and not pumping ? Popcorn[/img]
95lightiningguy
95lightiningguy
Post  DILLIGASDAVE August 24th 2010, 12:53 am
89lxcoupe wrote:the pump works out of the car so its not the pump.........
Just because the pump "works" out of the car doesn't mean it's working correctly.
Have you tested the pro-comp pump yet to see how many seconds it takes to fill a gallon jug? that's the real test of an electric fuel pump's abilities. If you haven't done it yet, test the pump correctly first. Then if it can fill a gallon jug fast enough that's when you start looking for other problems.
And make no mistake while the ancient Holley red/blue/black pump design is "lacking" when compared to the newer Aeromotive & Magnafules design, the normal pro-comp lack of quality control & shortcuts when copying a part make this ancient design 100 times worse than it should be.
Post  89lxcoupe August 24th 2010, 10:51 am
it does fill up a gallon jug pretty fast but i haven't timed it ! i'll try to do that and see if its putting out like it should !
89lxcoupe
Post  DanH August 25th 2010, 9:23 am
we all know why you bought the pro comp pump . that leads to this -- did you use quality fittings , correct size lines , size of fuel tank outlet ? proper gage wire and connections ? you can sometime get away with cheap , other surpporting parts you can't Then there is the regulator
DanH
Post  the Coug August 25th 2010, 9:35 am
Why come on here and try to coat it with sugar when everyone knows different....get you a good pump and get on with it....and throw that POS in the Trash and let it be... fix the problem don't try and find a band-aid for it....
Post  ustahava67 August 26th 2010, 11:15 pm
I used a "Holley Black" Pro-comp pump on my car..... Last year at a Pinks arm drop race it started loosing pressure. I had to crank the regulator a full turn after each round. I got through that race and bought an Aermotive pump. .... Haven't had an issue with the fuel system since
ustahava67
ustahava67
Post  56Tbird August 27th 2010, 2:30 am
He probably didn't calll it a pro-comp pump ,because he knew Coug would have to flap his cocksucker as soon as he saw it. I run some of the pro comp stuff and like it real well. If my stuff sat in the driveway all the time it'd never tear up either.Coug ,you always run your mouth about your tech posts ...You don't help much , you just flap your trap...I got something you can flap on Bitch Twisted Evil king
56Tbird
56Tbird
Post  bbf-falcon August 27th 2010, 5:00 am
I went to test w/buddy last week and he had a new BG400 that would'nt pump up ove 3# of pressure.He would have traded that pos for a ProComp that night Evil or Very Mad
