How much will my truck haul?
So im looking to haul some rock for my driveway and im looking for suggestions on how much my truck will haul in the bed. Truck is a 01 F250 4X4 V10 short bed. I know ive had 3000lb in there with no problem, just lookin to cut down on the number of trips. A dump truck is not an option because of my friggin carport, so my options are limited.
Race Ready Fabrications- Posts : 619
Re: How much will my truck haul?
if you have a flat car trailer make 2ft high sides with plywood and 2x4 frame works great
res0rli9- BBF CONTRIBUTOR
my experiance with the super duty is if it doesnt blow the tires out you can haul it. ive had 2 paletts of seed 5000 pounds no trouble.
brad- Posts : 50
brad wrote:my experiance with the super duty is if it doesnt blow the tires out you can haul it. ive had 2 paletts of seed 5000 pounds no trouble.
XXXXXXXXXXXXXXXXXX2222222222222222222222
When you go to get the rock they will have weight scales and they should weight your truck and it will tell them what the max weight you can haul.
Lonewolf1970- Posts : 355
