Choice of Intake
Choice of Intake
My 460 mild street build has iron CJ heads, the Torino shaker set-up will not allow me to use a wide variety of intakes. I am told the Torker 2 will fit, I have a Stealth that is too tall. I'm sure the Performer will fit also. This is a stock -resto type project so the look is important. Any opinions on my options?
Matt
Matt
Magmatt- Posts : 4
Re: Choice of Intake
The factory iron scj intake isn't all that bad IMO if you looking for it to look correct.
I have the same car with shaker I have used the Torker II and it works good but now I use BT dual plane you have to take away the distance ring between the carb and bottom plate. here is how it`s look like
![Choice of Intake Torinoshaker004](https://2img.net/h/i594.photobucket.com/albums/tt28/Fordlord429/Torinoshaker004.jpg)
![Choice of Intake Ford470cui004](https://2img.net/h/i594.photobucket.com/albums/tt28/Fordlord429/ford470cui004.jpg)
hope it helps
hope it helps
fordlord- Posts : 24
» Intake Choice
» Help W/ Heads & Intake choice, go "Blue Thunder"??
» sr-71 headed 521ci carb and intake choice
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» New Ford Racing Performer RPM intake ported and NIB Victor intake for Dominator
