sr-71 headed 521ci carb and intake choice
maverick172
Page 1 of 2
Page 1 of 2 • 1, 2
i am putting together a sr-71 521 all forged bottom end compression will be around 10.4 with the combo i have
would like to know what i should run for a carb and intake would you guys use the trick flow mafia or the victor ?
also should i go 4150 carb or a 4500 dominator and 950cfm to small ?or go 1150cfm?
thanks Brad
thanks Brad
maverick172- Posts : 205
Re: sr-71 headed 521ci carb and intake choice
maverick172 wrote:i am putting together a sr-71 521 all forged bottom end compression will be around 10.4 with the combo i have
thanks Brad
How and where will this engine be used for 80% of the time...?
i will be using it on street 80% time but i do drive it hard .rmcomprandy wrote:maverick172 wrote:i am putting together a sr-71 521 all forged bottom end compression will be around 10.4 with the combo i have
thanks Brad
20% track time
Personally, I would use a ported, (not just port-matched), Victor for that application.
Dave De and maverick172 like this post
I would go with at least a 1050 Dominator.
Here is another intake option if they have any.
https://cnc-motorsports.com/eliminator-big-block-ford-460-cj-v-intake-manifold-fits-cj-heads.html
https://www.alkydigger.net/product/ELIM-CJ.html
I don't know if 738drvr got to try one on his SR-71 deal or not.
https://www.429-460.com/t28498-new-cj-intake
supervel45- Posts : 4499
maverick172 likes this post
how about the carb? dominator or 4150 ? 75% street 25% trackrmcomprandy wrote:Personally, I would use a ported, (not just port-matched), Victor for that application.
looks like a nice intake who knows how it performs but..supervel45 wrote:I would go with at least a 1050 Dominator.
A pump gas 521 with SR-71's is rather overkill but if you ever want to step it up you've got the heads. Assuming that hood clearance isnt an issue and its going to only rev to 6,500 or 7,000 Randy is correct that the Victor is best. You will gain more mid-range torque over the Mafia and below 7,000. The Victor will probably outperform the Mafia intake thru-out. Also realize that these SR-71 packages are tall where the intake is spaced up .800" and the Mafia is another .75" taller over the Victor. My tube chassis 69 should be similar to your Maverick it has a 6" outlaw hood and I dont have space for a carb spacer (SR's with a Mafia).
Suggest that you go 13.5 compression and use E-85. The engine will be happier and clean burning not to mention that the mid-range power will be way up.
Dominators on the street are okay just set the secondaries to be progressive. 1050 to 1250 is best.
Dave De- Posts : 797
Mark Miller and maverick172 like this post
Maverick is you order set in stone already?
If not there's what Dave said above about the E-85 and Mahle has P51/SR-71 Flat Tops for that.
With the bigish roller cam 272/280 you went with you could have gotten your 11/1 with 22cc Icons and 70cc chambers. They have the SVO/SCJ valve notches.
https://www.summitracing.com/parts/uem-ic861-030
If you enter in the shaved heads and 64cc chambers with the 22cc pistons you can get in the 11.9/1 range.
Just saying, if your order is not concrete yet.
Yes I have it all ordered already.
Ya I cannot run e85 as we do not have that in Canada
Hence why I had to keep compression down and I did not want to go over 11 .. I think it will be ok .. was hoping to get 750 hp out of this combo what you guys think?
maverick172 wrote:Yes I have it all ordered already.
^I say that's pretty close.
Check out the dyno numbers of this build with a 950 and a 1,200 Dominator. That's why I said at least a 1050.
https://www.yellowbullet.com/threads/528-pump-gas-ford-843hp-on-91.580279/
wow impressive 40 hp dif bewtween the carbs . i can get a brand new 1150 dominator for 1000$ a guy has one for sale prob will scoop it up .supervel45 wrote:maverick172 wrote:Yes I have it all ordered already.
is there much in setting up these carbs ?
maverick172 wrote:wow impressive 40 hp dif bewtween the carbs . i can get a brand new 1150 dominator for 1000$ a guy has one for sale prob will scoop it up .supervel45 wrote:maverick172 wrote:Yes I have it all ordered already.
If you run a Dominator, in your application, get a 1050 2 circuit with power valve[s].
Sounds good . What about a 4150 carb which one would you go with?
I don't know about now but, a few years ago the 950 QFT did a good job.
I will try do a bit more research on carb choice
Not all 950's are 950cfm. The HP950 List# 80496 is more like 840cfm. It's a 750 body with a 850 baseplate basically.
Like Lem said 2 circuit 1050 with power valves for the mixed use driving.
Holley 8082 fits this criteria and the 8082-1 shows 2 PV's. I'd block off the rear one and jet up.
Here's a good video, curtesy of Tunner, on Dominator carburetor's.
https://www.youtube.com/watch?app=desktop&v=JW21G0o1bdk
If you want tuning info this place is the best for a website format I have found.
http://www.racingfuelsystems.com/viewforum.php?f=5
thank you for the help guys . i will do some more research and let you know.supervel45 wrote:Here's a good video, curtesy of Tunner, on Dominator carburetor's.
so how about these quick fuel or pro form carbs ? are they 2 ciruit or 3 circuit they do not seem to list what they are . from what i have read 2 circuit much easier to tune .maverick172 wrote:thank you for the help guys . i will do some more research and let you know.supervel45 wrote:Here's a good video, curtesy of Tunner, on Dominator carburetor's.
thanks Brad
Below is an old thread. Still a lot of good info. JMark is bigtime now and won the CMC shootout with his Dominator on a small block a few years ago, and that is his website in the previous link. Tunner, JMark and Yetti know the scoop on these Holley's and the other carburetors as well.
https://www.speed-talk.com/forum/viewtopic.php?f=1&t=9934
maverick172 wrote:so how about these quick fuel or pro form carbs ? are they 2 ciruit or 3 circuit they do not seem to list what they are . from what i have read 2 circuit much easier to tune .maverick172 wrote:thank you for the help guys . i will do some more research and let you know.supervel45 wrote:Here's a good video, curtesy of Tunner, on Dominator carburetor's.
thanks Brad
I would stay away from Proform, and stay with a 2 circuit.
Here is an older Quick Fuel Catalog. It shows witch one are 2 and 3 circuit models.
https://images.carid.com/quick-fuel-technology/info/qft-catalog.pdf
Dave De likes this post
Dave De wrote:A pump gas 521 with SR-71's is rather overkill but if you ever want to step it up you've got the heads. Assuming that hood clearance isnt an issue and its going to only rev to 6,500 or 7,000 Randy is correct that the Victor is best. You will gain more mid-range torque over the Mafia and below 7,000. The Victor will probably outperform the Mafia intake thru-out. Also realize that these SR-71 packages are tall where the intake is spaced up .800" and the Mafia is another .75" taller over the Victor. My tube chassis 69 should be similar to your Maverick it has a 6" outlaw hood and I dont have space for a carb spacer (SR's with a Mafia).
Medium or Moderate Progressive on the Secondaries for street use on the Dominator?
Mark Miller- Posts : 1959
Mark Miller wrote:Dave De wrote:A pump gas 521 with SR-71's is rather overkill but if you ever want to step it up you've got the heads. Assuming that hood clearance isnt an issue and its going to only rev to 6,500 or 7,000 Randy is correct that the Victor is best. You will gain more mid-range torque over the Mafia and below 7,000. The Victor will probably outperform the Mafia intake thru-out. Also realize that these SR-71 packages are tall where the intake is spaced up .800" and the Mafia is another .75" taller over the Victor. My tube chassis 69 should be similar to your Maverick it has a 6" outlaw hood and I dont have space for a carb spacer (SR's with a Mafia).
Just set it up so that they are not 1 to 1. The second setting will allow better feel on the secondaries even though they will come in sooner. In most cases on the street you cant use the secondaries anyway.
Dave De wrote:Mark Miller wrote:Dave De wrote:A pump gas 521 with SR-71's is rather overkill but if you ever want to step it up you've got the heads. Assuming that hood clearance isnt an issue and its going to only rev to 6,500 or 7,000 Randy is correct that the Victor is best. You will gain more mid-range torque over the Mafia and below 7,000. The Victor will probably outperform the Mafia intake thru-out. Also realize that these SR-71 packages are tall where the intake is spaced up .800" and the Mafia is another .75" taller over the Victor. My tube chassis 69 should be similar to your Maverick it has a 6" outlaw hood and I dont have space for a carb spacer (SR's with a Mafia).
Thanks right now it looks like i'm at the Moderate Progressive Set Up Black Rod Hole #3 on my Quick Fuel QFX-4700 1050 Dominator!!
Page 1 of 2 • 1, 2
» Choice of Intake
» carb choice
» What is your carb of choice?
» weiand carb adapter 4500 carb flange to 4150 intake
» Intake Choice
» carb choice
» Intake Choice
Page 1 of 2
