What is your carb of choice?
kim
Super Snake Steve
sg86coupe
Starting my research on what carb for my new motor. What do you have, and would you buy another one. What would you buy and why?
sg86coupe- Posts : 184
Re: What is your carb of choice?
Kind of vague you have to tell what your motor is what is in and what you plan on doing with it with what you just asked I'd say go with something From 750cfm to 1400 CFM and you'll be happy oh and I'd use either 4150 or dominator Flange make sure your tune is right on the money
Super Snake Steve- Posts : 141
That's the one I would pick also.Super Snake Steve wrote:Kind of vague you have to tell what your motor is what is in and what you plan on doing with it with what you just asked I'd say go with something From 750cfm to 1400 CFM and you'll be happy oh and I'd use either 4150 or dominator Flange make sure your tune is right on the money
supervel45- Posts : 4499
I'm asking what company would you choose APD, AED Quickfuel, Holley. I'm not asking what size, i will have who ever I chose to build it to spec. What company has a good product and a good tech support
I have always liked Holley. I would never let them spec. a carburetor for me though.
The largest HOLLEY which THAT engine will accept to start.
Then modify it and use parts from whoever and whatever it needs.
I called Holley for help on my current carb, they weren't much help.
https://www.429-460.com/t21137-a-head-547 I guess it's this engine? Didn't think Holley would be much help, like I said I would not even let them size a carb. for me. You have a 1050 now?
Don't waste your time with buying 4 jets. Order a complete jet kit and get it over with. Bring them to the track and tune it, along with a hand full of shooters and and pump cams.
Randy I know you know how to do that, I do not. I don't even know if I need a 2 or 3 circuit or what. But I appreciate any help.
Supervel45 yes thats my motor. I know a 1050 is to small and it's really fat at idle, not sure why. So researching what company to get a bigger carb from.
If you want to spend a lot of money on a carb. that is as close as possible, I would recommend Quickfuel. The main reason is because Defree383 used one on his 572 EMC engine. I would ask them what they can do for the Holley you have first and see if they can do anything with it, to save some money. You still need jets and to learn to tune a carb. though for varying weather and track conditions for best results.
B-7395 Severe-Duty Carburetors
The Braswell B-7395 was specifically designed for single 4 bbl applications. Building on the design and record setting performances set forth by the B-7520 2 bbl carburetors, the B-7395 has been taking the single 4 bbl carbureted engine performance to new levels. These carburetors are designed to be used where a single 4 bbl or "Whole" carburetor is mandated by rules or preferred for packaging reasons. Their design allows them to be machined in a wide range of sizes necessary for today's competition engines. They offer the ultimate in performance for Competition Eliminator, Top-Sportsman, Top-Dragster, Quck-8, and Outlaw racing.
CNC machined from high quality aluminum die-castng, the B-7395's are offered in a wide range of sizes to accommodate race engines from 600-1600 plus horsepower for single 4 bbl use. They feature spread throttle bores for better fuel distribution, loner venturis for smoother fuel metering and an innovative metering system. The fuel jets and their pickups are located so they remain in liquid fuel even when acceleration rates exceed 3.5 G's, while allowing the use of power valves for additional tuning if needed. The light weight billet metering blocks feature a lengthened main metering well and multiple bleed systems providing improved metering and tuning flexibility unavailable in the past. The manifold mounting flange can be used with either the industry standard 5.38" x 5.38" hole mounting pattern or the optimized 5.50" x 5.50" hole mounting pattern. The air cleaner flange has been enlarged to an even 8.00" diameter. Venturi sizes range from 1.90"-2.18", and 2.20"-2.25" throttle bores. There are also two different size booster venturi castings allowing these carburetors to be tailored to the demands of today's racing engines.
Features:
•Calibrations for naturally aspirated, N2O or draw through supercharged applications
•Can be built for either manual or automatic transmissions
•Replaceable air bleeds, idle feed restrictors,intermediate jets
•4 circuit metering standard
•2.91" Throttle bore centers pattern
•8" Scoop tray opening
•Industry standard 5.38" x 5.38", and 5.50" x 5.50" hole mounting pattern
•Fuel Chute II bowls with large glass fuel site windows
•Severe-Duty floats
•Fully adjustable billet metering blocks
*Talk to your salesperson to find out about manifold spacers, shear plates, fuel fittings, gasket sets, tuning kits, and other available accessories to get the most performance out of your new Braswell B-7395 Severe-Duty carburetor*
Two would be better....
The Braswell B-7390 was specifically designed as a dual 4 bbl application. Building on the design and record setting performances set forth by the B-7520 2bbl carburetors, the B-7390 has been taking 4 bbl carbureted engine performance to new levels going to the finals in the first NHRA Pro-Stock race where they were legal. These carburetors are designed to be used where a 4 bbl or "Whole" carburetor is mandated by rules or preferred for packaging reasons. Their design allows them to be machined in a wide range of sizes necessary for today's competition engines. These carburetors offer the ultimate in performance for Pro-Stock, Competition Eliminator, Top-Sportsman, Top-Dragster, Quick-8, and Outlaw racing.
CNC machined from high quality aluminum die-castings, the B-7390's are offered in a wide range of sizes to accommodate engines from 900-2200 plus horsepower for dual 4 bbl use. They feature spread throttle bores for better fuel distribution, longer venturis for smoother fuel metering and an innovative metering system. The fuel jets and their pickups are located so they remain in liquid fuel even when acceleration rates exceed 3.5 G's. The light weight billet metering blocks feature a lengthened main metering well and multiple bleed system provide for improved metering and tuning flexibility unavailable in the past. The carburetor mounting flange can be used with either the industry standard 5.38" x 5.38" hole mounting pattern or the optimized 5.50" x 5.50" hole mounting pattern. The scoop tray flange has been enlarged to an even 8.00" diameter. Venturi sizes range from 1.90"-2.18", and 2.20"-2.55" throttle bores. there are also two different size booster venturi castings allowing these carburetors to be tailored to the demands of today's racing engines.
•Features:
•Calibrations for naturally aspirated or N2O applications
•Replaceable air bleeds, idle feed restrictors, intermediate jets
•Available with either 4 or 5 circuit metering
•2.91" Throttle bore center lines
•Fuel Chute bowls with large glass fuel level site windows
•Severe-Duty floats
*Talk to your salesperson to find out about manifold inserts, shear plates, fuel fittings, gasket sets, tuning kits, and other available accessories to get the most performance out of your new Braswell B-7390 Severe-Duty carburetor*
Features:
•Severe-Duty floats
•Features:
•Severe-Duty floats
kim- Posts : 700
http://www.yellowbullet.com/forum/showthread.php?t=340888&page=10 ^^^^^^^
Hmm, interesting what Big Chief said about them before he went fuel injected. The prices on their small parts look extremely reasonable compared to what Holley gouges you for them. Don't see many used ones for sale if that means anything either.
sg86coupe wrote:Starting my research on what carb for my new motor. What do you have, and would you buy another one. What would you buy and why?
Ive used a lot of diff brands, The ones I like the best are PRO SYSTEMS, I have used, installed, and or sold them since the late 90s.
from 4150 style ,4500 doms,and the sv1's . we have tried others on the dyno, and just stay with PS
-Rich
BOSS 429- Posts : 2372
Give Phillip Oakley a buzz, he'll help you get the right carb and he is a Quick Fuel and Holley dealer
quickfuel has always done me well.
Quickfuel or holley here as well
gmsmkr- Posts : 1364
sg86coupe wrote:Randy I know you know how to do that, I do not. I don't even know if I need a 2 or 3 circuit or what. But I appreciate any help.
Of course you start with something "out of the box" but, until you know the particular idiosyncrasies about any particular combination, everything will simply be a "best guess" done from experience with like combinations.
You gotta start somewhere so, it should be the point of getting the carburetor SIZE correct and work from there, tuning or changing whatever it needs.
You are right ... not so simple but, it is the best way to get to your desired ending.
» carb choice
» sr-71 headed 521ci carb and intake choice
» weiand carb adapter 4500 carb flange to 4150 intake
» Help me on engine choice
» Valve choice
» Valve choice
