carb choice
carb choice
Help please!!! Is a 1050 Dominator too big of a carb for a mild 466?? If not, what brand would be better choice, Quick Fuel or Holley?? Any particular part number. Any help is appreciated!
mikey hefner- Posts : 79
Re: carb choice
I ran an 1150 Holley on top of my 466 in a mud drag truck and it did ok. the trick is getting everything else to work together with it.
kjett- Posts : 1169
Re: carb choice
Please explain, what you mean about getting everything else to work with it. I'm a newbie in this exciting world of th BBF. ANY info is appreciated!!
Re: carb choice
the 466 in my '68 mustang had a 1050 and went 10's
Larry Williams- Posts : 884
Re: carb choice
Meaning you need to work out the whole build package to work together. From block prep, rotating assembly, heads/valve train, oiling system, intake, and exhaust. It's a whole package that needs to work together and you can't just throw parts together and expect success. My original build is here:
https://www.429-460.com/t5399-466-ranger-build
kjett- Posts : 1169
Re: carb choice
Understood, the motor I have now came from another car, not sure of all the particulars of it, just its a mild .030 over 460. It's equipped with a performer rpm manifold and a 950 alky carb right now with iron heads, and the 2in hooker swap headers. The alcohol is dificult to deal with while its so cold. Just thinking of going to a gas carb. I'm planning on a 521 or 545 build in the near future. Thinking of the Mafia intake and a 1050 and transfering it to the new motor when completed. Just wanted to see if that the change would be too much for what I have right now.
Re: carb choice
1050 without a doubt, hell i run a 950 QF gas carb in my 306" sbf
» What is your carb of choice?
» sr-71 headed 521ci carb and intake choice
» weiand carb adapter 4500 carb flange to 4150 intake
» Choice of Intake
» Best rad choice
» Choice of Intake
» Best rad choice
