Best rad choice
Best rad choice
My '77 4x4 street rod still has the 351M radiator, water pump is now a weiand high flow and using a Mark VIII fan, temp is fine for cruising but stay on the throttle hard and it quickly rises. Looking at the Bronco Graveyard thay have a Super Cooler rad and an aluminum flex-a-lite rad, which would give the best bang for the cooling buck? Thanks.
77f150- Posts : 220
Re: Best rad choice
get one for 460 with ac, it'll cool it.
res0rli9- BBF CONTRIBUTOR
Re: Best rad choice
res0rli9 wrote:get one for 460 with ac, it'll cool it.
I'll check it out, thank-you.
77f150- Posts : 220
Re: Best rad choice
I got one from Champion, it was a huge 4 core and keeps my puller cool all the time. And the price is good also
79Puller- Posts : 193
Re: Best rad choice
I'm still using an origonal brass radiator in my bronco with a mild 460. I'm using a 2-speed fan from a taurus with a/c. Mounted it on some aluminum brackets right to the factory holes. It keeps it relatively cool on the hottest of days climbing the dunes.
sandvipr- Posts : 29
Re: Best rad choice
I decided to get the Super Cooler rad from Bronco Graveyard (#20604), I compared it to the NAPA list price for the identical rad here in Canada.......are you ready..........$922.45 ($553.47 dealer cost). Damn good thing the dollar is almost par
77f150- Posts : 220
» Wonder how trany shops are welding input to drum and getting it perfectly straight?
» help with transmission choice
» carb choice
» 87 - ZF 5 Speed & 460 into 75 Highboy? Anyone???
» cam choice help 552 stroker
» carb choice
