Intake Choice
Intake Choice
Ok I have been lurking here for a while but this is my first post.
I have built a few BBF's in jet boats, but I am stuck on my current question.
The Motor is a D1VE block .080 over with SRP flat tops(almost 11:1), Scat H-beam rods, ARP main studs.
- Heads are ported C9VE's w/2.19, 1.76 valves.
-Cam: Comp Cam Magnum 300A-R10(solid roller)
-Intake was a Weiand tunnel ram w/2 750dp Holleys
-Rewarder open headers
I had this combo in an 18ft Kachina Jet boat Spinning an Aggressor B cut bronze impeller to 5900Rpms @ 93mph.
I am putting this motor in a 21ft Eliminator mini day which is a bit heavier( going to run same Impeller), plus I am not going to run the tunnel ram so I can keep the engine under the cover. I am changing the exhaust to Lightening water jacketed headers through transom. So here is the big question, which intake and carb to run to get same performance as the tunnel ram? I was thinking a FMS with a 1050 Dominator. Which intake lines up the best with Factory heads? Does the Victor or TFS work better? What about a Port O Sonic with a Dom flange? I have also never ran a Dominator carb, which is recommended 2 circut or 3?
nosfomoco- Posts : 4
Re: Intake Choice
With your situation I would use a Torquer II intake with a 1 inch thick "Cloverleaf" spacer, (a TFS "Track Heat" if you wish to spend the extra money for only a few more horsepower), and start with one of your 750's
You won't need a Dominator for a 477 at only 5,900 RPM.
Re: Intake Choice
rmcomprandy wrote:With your situation I would use a Torquer II intake with a 1 inch thick "Cloverleaf" spacer, (a TFS "Track Heat" if you wish to spend the extra money for only a few more horsepower), and start with one of your 750's
I tried a Torquer II once when i was first testing that motor with a 800 DP Holley, lost 500 Rpms to the Tunnel ram and Dual 750's. I thought BBF's in Jets needed a lot of fuel?
Re: Intake Choice
''nosfomoco wrote:rmcomprandy wrote:With your situation I would use a Torquer II intake with a 1 inch thick "Cloverleaf" spacer, (a TFS "Track Heat" if you wish to spend the extra money for only a few more horsepower), and start with one of your 750's
Then remove or cut a hole in the engine cover and get what you think you should have.
Change the heads and quit screwin' around with stuff that barely matters.
Re: Intake Choice
i would shy away from the port o sonic , ran 2 different port o sonics (sent the first one back) and both were cast wrong. the intake ports were in the wrong location on one side of the manifold. had a proplem sealing the ports on one side . drove me nuts for a long time till i discoverd the problem. switched to a weind, problem solved ! now run a edelbrock victor and love it . for the boat i would recomend either .
1fatcat- Posts : 44
» Choice of Intake
» sr-71 headed 521ci carb and intake choice
» Help W/ Heads & Intake choice, go "Blue Thunder"??
» Eliminator Big V Intake Vs KFM Custom Trick Flow A460 single Dominator Intake
» help with gear choice
