Hey what do you adjust valves at?
DanH
Moodyblues
I always set my valves at .24 cold. I have a D0VE headed 514. What do you set yours at?
Re: Hey what do you adjust valves at?
I start with -what the cam card calls for .
DanH- Posts : 1081
DanH wrote: I start with -what the cam card calls for .
X2.....
The cam card does'nt take in consideration if its a iron/alum head. W/my alum. heads I set them .006 tighter cold than what the spec. card says..004 if it's a iron headed deal. Thats just me
Well I have a custom ground cam and there are no settings on the card. My engine buider gave me the setting to run them on. Roller motor with a iron D0ve head, .747/737 lift shifted at 5800-6200. I was just wondering what everybody else did, no big deal
.018 to .026 is a pretty common range. Tighter is better than looser for valvetrain life.
One needs to take into consideration, that aluminum and iron expand differently. I was taught that if you have iron heads, the gap will tighten as everything get warmer vs. loosening when it gets warmer for aluminum. I run my SCJ's @ .012 cold, and they're right at .016 hot. I did a couple sets of irons that I set @ .020-.022 cold, and they closed up to .016-.018 when hot. I run mine where they are, because it likes it there. It obviously runs pretty fair there.
Just my experience.
Doug...
Just my experience.
Doug...
ThndrChkn- Posts : 2216
the iron heads will tighten up with heat.some set as loose as .030 that i'v ran.much as i hate to do it the best way is start at .030,heat it up and check it.i set my A460's at .020 and end up at .026 hot.
» how to adjust valves on stock 460
» the dove c heads i bought , i measured the intake valves they were 2.250 assuming these are not stock valves ?
» 429 SCJ original ( used ) intake valves and NOS 2.19 PI valves - price lowered and shipping included!
» TDC valve adjust question
» C6 shifter, which one adjust correctly?
