Need direction or advice on the build...
O-Deuce Coupe
I'm starting a new build this coming weekend. It's a tin can '82 Notchback. My goal is 11 flat 1/4mi with no power adders. I can get E-85 all day long and I'd like to take advantage of it if possible. I'm on somewhat of a budget but I can spring for the right parts if needed. I already have a stock 460 with D3VE-A2A heads that needs rebuilt. Here's what I have thinking about and I could be way off base but here goes:
-stock crank
-truck rods with ARP's
-hyper-crack-tic pistons and moly rings 12-ish to 1 comp.
-ported dove's?
-261/268 @.050 .667/.657 solid cam
-swap pan
-swap mounts
-stealth intake
-850 dp Holley
-Hooker swap headers
-TCI streetfighter and 3000 stall
-4.10 gears and 28" DOT's
-about 3000lb race weight
This is a rough idea so all input is welcome. I want a solid plan before I dig in, it gives me something to look foward to.
-stock crank
-ported dove's?
-swap pan
-swap mounts
-stealth intake
-850 dp Holley
O-Deuce Coupe- Posts : 21
Re: Need direction or advice on the build...
Victor and a 1050 is a better choice IMO you shouldn't have any problem running 11s with what you've described
plus invest in a set of hbeam rods and some better pistons.
sounds like a great build x2 invest in some better pistons if there is room in the budget im sure other engine gurus will chime in
Decent ported DOVE's and a Victor with a dommie and you will probably get closer to the 10's than 11's. Definately do the better rods and forged pistons. Relatively cheap upgrades and worth the peace of mind.
schmitty- Posts : 4538
Looks pretty good, yes if the money is there I'd get h beams and a forged piston be it a sealed power or the like.
I did run 10.70's in the head with a 466, sp flat top, stock rods, ported Doves, 10-1 comp, T2 intake, 1050 alky carb. This was at 3300#'s
I ran 11.20 @ 119mph with a 466 in a 3300 pound mustang. It had Srp flat top pistons about 11.7 to 1 compression, truck rods, home ported Dove heads with stock valves, lunati solid cam(237/247 deg. @ .050), stealth intake, tci super streetfighter(3600-3800rpm), 3.73 gear, 28" slick, C6 trans, super comp headers. Then I put a bigger solid cam(294 comp cam) and ran 10.8 @ 123mph, but the stock conecting rods didn't like 6700Rpm with larger cam.
501ranger- Posts : 54
sorry double post
Last edited by 501ranger on August 26th 2009, 9:18 pm; edited 1 time in total (Reason for editing : double post)
Wow that pretty close to what I had in mind. So pistons will definately be on the list then.501ranger wrote:I ran 11.20 @ 119mph with a 466 in a 3300 pound mustang. It had Srp flat top pistons about 11.7 to 1 compression, truck rods, home ported Dove heads with stock valves, lunati solid cam(237/247 deg. @ .050), stealth intake, tci super streetfighter(3600-3800rpm), 3.73 gear, 28" slick, C6 trans, super comp headers. Then I put a bigger solid cam(294 comp cam) and ran 10.8 @ 123mph, but the stock conecting rods didn't like 6700Rpm with larger cam.
Do the hbeams too, it's only a couple more $$$ than reconing and adding bolts to you truck rods......
Right on, more research to do
I would sugest a looser convertor and smaller cam. The 294 solid cam I had for awhile needed a looser converter. Even though the bigger cam made my mustang faster it lost about 0.06 in the sixty foot, since the super streetfighter was to tight for the bigger cam.
» Need direction...... Again 528 build
» 554 ci engine build advice
» new build need advice
» build advice
» New build advice
» build advice
» New build advice
