Gas Ported Piston
Gas Ported Piston
When does it become necessary to use gas ported piston ?
Todd
Todd
ToddB- Posts : 35
Re: Gas Ported Piston
1/16" top rings do not need them.
.043" Dwall ...good idea.
.043" back cut...for sure.
I.M.O.
I.M.O.
it makes more power,so if rules allow we use a piston with the right ring pac
BOSS 429- Posts : 2372
Thin lightweight ring packages,,,gas ported pistons,,,and a vacuum pump all go together. They are like "enablers" and support each other.
Hope this helps,
Charlie
Hope this helps,
Charlie
c.evans- BBF VENDOR SPONSOR
Can you run gas ported pistons on a nitrous motor? Do you have a better chance of having problems?BOSS 429 wrote:it makes more power,so if rules allow we use a piston with the right ring pac
James Hahn- Posts : 23
» WTT: Ported D0VE's for ported D3's
» Anyone know how close the Forged L2366f piston is to cast 429 piston?
» question about cnc ported heads
» Ported A429's Valve Job
» ported tfs streets
