vacuum pump
KY JELLY
vacuum pump
I got Travis' vac pump on had to go with a 2" crank pulley 1 " smaller than what was with it due to space limitations . It will pull 12" in just a little bit, gonna have to turn down the relief . I guess there ain't nothing wrong with that Lem Evans ring package . .
If I didn't know better I would swear there was a pair of e vac tubes stuck in Fabio's cheeks pullin on that sucker
KY JELLY- Posts : 1530
Re: vacuum pump
I take it this is not the elec smog pump deal you got from Lem, those pumps are good for about 4" on a non running engine.
Re: vacuum pump
he was a no show. on the elect pump.richter69 wrote:I take it this is not the elec smog pump deal you got from Lem, those pumps are good for about 4" on a non running engine.
He did say crank pulley so it's gotta be belt driven.
Re: vacuum pump
That deal will work..............
Re: vacuum pump
KY JELLY wrote: I got Travis' vac pump on had to go with a 2" crank pulley 1 " smaller than what was with it due to space limitations . It will pull 12" in just a little bit, gonna have to turn down the relief . I guess there ain't nothing wrong with that Lem Evans ring package . .
Good deal. Now don't panic when you shut the car off and it whistles as it bleeds the pressure off. Sometimes its pretty loud.
Travis
TravisRice- BBF CONTRIBUTOR
Re: vacuum pump
5" pump , was 3" pulley on crank with the mandrel and combo I sent him, Now at 2"crank pulley.
Travis
Travis
Re: vacuum pump
Should note that it is a 4 vane Moroso for a dry sump setup. I ran it on my wet sump deal just limited the vacuum with a cheap ass releif valve. Never had a minutes problem.
I told Randy that a friend has one that is 1;1 driven on a B-1 Mopar engine. Barton recomended as much vacuum as he could pull. Wet sump also, No gauge, You can actually see it suck the tops of the valve covers down when he free revs it with the hood off. It's gotta be starving something of oil somewhere , I'll let you know when it flies apart.
Travis
Travis
Re: vacuum pump
yOUR ASS....................
342g- BBF CONTRIBUTOR
Re: vacuum pump
342g wrote:richter69 wrote:I take it this is not the elec smog pump deal you got from Lem, those pumps are good for about 4" on a non running engine.
Re: vacuum pump
CaMeL tOe!
Re: vacuum pump
Is that pump a Swedish model???
Re: vacuum pump
polishamishrichter69 wrote:Is that pump a Swedish model???
» vacuum pump!
» Vacuum Pump
» which vacuum pump?
» vacuum pump ?
» vacuum pump!
» Vacuum Pump
» vacuum pump ?
