D9 Block .30 over
The Pope
R_Williams
71torino
Old blue Racin Team
D9 Block .30 over  Empty D9 Block .30 over
Post  Old blue Racin Team October 4th 2010, 2:17 pm
I have a D9 Block Fresh out the machine shop .30 over
$300
Im in Stella NC 28582
Old blue Racin Team
Old blue Racin Team
D9 Block .30 over  Empty Re: D9 Block .30 over
Post  Old blue Racin Team October 5th 2010, 8:03 am
TTT
Old blue Racin Team
Old blue Racin Team
Post  71torino December 23rd 2010, 12:20 pm
Do you still have the block? Any pics?
71torino
71torino
Post  R_Williams December 23rd 2010, 3:10 pm
Hey blue, where is stella at in NC Im looking for a block...........................
R_Williams
R_Williams
Post  Nevs December 23rd 2010, 3:22 pm
R_Williams wrote:Hey blue, where is stella at in NC Im looking for a block...........................
Just east of Jacksonville...
Post  R_Williams December 23rd 2010, 3:24 pm
cool thats only about 2 hours from me. Are the D9 blocks better than the production/stock blocks?
R_Williams
R_Williams
Post  Nevs December 23rd 2010, 3:26 pm
R_Williams wrote:cool thats only about 2 hours from me. Are the D9 blocks better than the production/stock blocks?
Cylinders are a little longer than the earlier (C8, C9, Dove, D1, etc.) blocks. Strength wise, no difference, but the longer cylinders are nice for a stroker build.
Post  R_Williams December 23rd 2010, 3:29 pm
Is that the only difference? Deck height and everything else is the same?
R_Williams
R_Williams
Post  Nevs December 23rd 2010, 4:12 pm
R_Williams wrote:Is that the only difference? Deck height and everything else is the same?
That's the only difference I am aware of.
Post  R_Williams December 23rd 2010, 4:14 pm
Would there be any other machining that would need to be done to the block for a stroker?
R_Williams
R_Williams
Post  Nevs December 23rd 2010, 4:15 pm
R_Williams wrote:Would there be any other machining that would need to be done to the block for a stroker?
No, this isn't a BBC block it's a Ford 460 block. 4.500" stroke will work fine without any grinding.
Post  R_Williams December 23rd 2010, 4:31 pm
cool thanks! PM Sent!
R_Williams
R_Williams
Post  The Pope December 23rd 2010, 7:44 pm
D9's need an External Balanced Crank and the hatchat weight.
R_Williams, Where are you located? I'm near Raleigh.
The Pope
The Pope
Post  R_Williams December 23rd 2010, 7:47 pm
Dont most stroker kits now use the externally balanced crankshafts that will fit in the D9? Im just outside of Fayetteville..........
R_Williams
R_Williams
Post  Nevs December 23rd 2010, 8:17 pm
The Pope wrote:D9's need an External Balanced Crank and the hatchat weight.
I don't believe that is the case with the aftermarket cranks. At least not in my experience.
Post  R_Williams December 23rd 2010, 8:20 pm
I was researching the D9s on here and it says that pretty much everybody is making cranks that are compatible with these blocks nowadays
R_Williams
R_Williams
Post  The Pope December 24th 2010, 8:20 am
Good deal then. Just wanted to make you aware of a possible issue with cranks in a D9 block.
The Pope
The Pope
Post  R_Williams December 25th 2010, 12:07 am
The Pope wrote:Good deal then. Just wanted to make you aware of a possible issue with cranks in a D9 block.
Thanks man, I came across a deal I just couldnt refuse today............ Heres what I got:
a fully machined D1 block bored 030 over (just needs cam bearings and freeze plugs)
a seperate complete D1 460 motor with D3 heads and everything I need to rape for the other other motor Very Happy
a spare 3.85 crankshaft
a complete C6 trans
a complete 289 motor
a complete fordomatic trans
all for $500
R_Williams
R_Williams
D9 Block .30 over  Empty internally balanced crank
Post  new2460 December 25th 2010, 12:53 am
as long as you use an internally balanced crank the block doesnt know. correct?
new2460
Post  138 December 25th 2010, 3:35 am
138
Post  Wayne Pearce December 25th 2010, 9:30 am
Internally balanced rotating assembly's can be fitted to D9 blocks. A lot of grind and fit, but worth the effort.
Wayne (SAWDOFF) Pearce
Wayne Pearce
Post  Paul Kane December 25th 2010, 11:11 pm
new2460 wrote:as long as you use an internally balanced crank the block doesnt know. correct?
The OEM passenger car internal balance crankshafts are not a drop-in deal with the D9TE block.
