Ky bust's a pinion support
+13
bcr466
KY JELLY
56Tbird
138
17 posters
Ky bust's a pinion support Empty Ky bust's a pinion support
Post  IDT-572 October 16th 2010, 8:14 pm
Talked to Ky , looks like he ripped out his pinion support. He went a 5.10 pass first time trial.
The tune was lean because the new air pan was pushing more air in the engine and the barometer was high also. He richened up the tune for the next pass and left at 6000 rpm.
That"s when the carnage ensued............. Rolling Eyes Too much Cow Bell Twisted Evil Embarassed Shocked affraid
Ky bust's a pinion support Empty Re: Ky bust's a pinion support
Post  DILLIGASDAVE October 16th 2010, 9:19 pm
If Randy is using a 3/8" stud pinion support, sounds like he's making enough power that it might be time for the 7/16" stud stuff. Is he running a standard or big pinion gear set?
Post  IDT-572 October 16th 2010, 9:22 pm
I couldn't tell you Dave , sorry I don't know. Rolling Eyes
Post  Nevs October 16th 2010, 9:29 pm
DILLIGASDAVE wrote:If Randy is using a 3/8" stud pinion support, sounds like he's making enough power that it might be time for the 7/16" stud stuff. Is he running a standard or big pinion gear set?
I would hope he's running a big pinion! Otherwise, get used to breaking stuff!
Post  138 October 16th 2010, 9:39 pm
speaking of pinion support studs...anyone have any ss studs they wanna sell?... and sorry to hear he broke shit
138
Post  56Tbird October 16th 2010, 9:43 pm
I know he's running a pro gear...
56Tbird
56Tbird
Post  DILLIGASDAVE October 16th 2010, 9:56 pm
It's amazing how much the price jumps from the small pinion pro gear to the big pinion pro gear, even though it's the same material. Not to mention a few more dollars for the big 1-1/2" socket for the big-assed pinion nut. Laughing
Post  richter69 October 16th 2010, 10:18 pm
if he needs a big pinion 4.86 pro gear I got a real nice one I'd let go.............. Wink
Post  KY JELLY October 17th 2010, 2:12 am
It appears to have pushed the pinion support out pulling out the bolts and heli coils. I don't know if it broke a gear first and caused this or not. I will pull it out tomorrow. This was a light weight strange case with the big pinion pro gears.
I guess I am gonna step up to the ultra case with 12 pinion support studs. and put my 4:30 gears back in Cool
On a positive note Wes ran a 5.43 cheers
KY JELLY
KY JELLY
Post  bcr466 October 17th 2010, 11:22 am
Think you will make it to Jackson for finale?
bcr466
bcr466
http://cracing@frontiernet.net
Post  KY JELLY October 17th 2010, 2:38 pm
Gonna try to make Jackson Bcr.
KY JELLY
KY JELLY
Post  richter69 October 17th 2010, 2:43 pm
look the tranny over good...........
Post  KY JELLY October 17th 2010, 5:32 pm
What are you referring to the planitaries , don't see any damage externally, there was no gears broken looks like it just pushed the pinion support out, it did chew on the ring gear after it jumped forward.
Launch before it broke , smooth as silk 5 numbers better 60' and 8 mph faster than last outing at Holly springs Mississippi
KY JELLY
KY JELLY
Post  138 October 17th 2010, 6:38 pm
so I guess its safe to say that it was not your car when referring to the drama you had not to long ago with a track owner/promoter...
138
Post  56Tbird October 17th 2010, 9:33 pm
I really can't see how these things take the abuse we throw at them!! It's amazing they make a pass without busting something...Mine usually doesn't make a weekend without something needing repaired anymore. affraid Dang u-joints are amazing to take that kind of power time after time. Good luck Randy ,if I got anything you need ,just let me know.. king
56Tbird
56Tbird
Post  richter69 October 17th 2010, 10:04 pm
just seems something always get shocked in the tranny when the pinion gets jammed forward like that. ..........
Post  bruno October 17th 2010, 10:07 pm
damn that hurt ....glad everything is ok .....
http://WWW.CKRME.COM
Post  cool40 October 17th 2010, 10:44 pm
so,now you know the driveshaft loop works. Smile not that you realy wanted to know. Sad i have some 4.30 35spline pinion gears if you need them.that thing leavs sooo hard it'll be tuff on parts. Laughing
Post  KY JELLY October 18th 2010, 12:19 pm
One bolt bolt that was lodged in held the pinion support in place so the drive shaft did not whip anything it just turned.
I appreciate the offers with the gears , but I got a large pinion 4:30 I am going to put in. Strange said those light weight aluminum cases were originally built for 1800 lb dragsters so I was pushing my luck anyway Smile
I got one of these on the way
http://www.strangeengineering.net/catalog/pdf/031.pdf
KY JELLY
KY JELLY
Post  Lem Evans October 18th 2010, 12:51 pm
Is it rated for M5?
Post  richter69 October 18th 2010, 12:52 pm
they make green 75-140 also................. Smile
Post  KY JELLY October 18th 2010, 1:22 pm
That depends on what the m-5 is being burned in Shocked
KY JELLY
KY JELLY
Post  whatbumper October 18th 2010, 3:07 pm
KY JELLY wrote: I got one of these on the way
That's what i have. you'll love it. Even though it's aluminum it's not a lightweight but it's been good to us.
Post  138 October 18th 2010, 4:25 pm
how do those compare to the strange nodular cases? I got a 28 spline daytona pinion setup with a richmond gear 33 spline spool, I intend on 850-950hp n/a, powerglide, 3000lbs.... pushin it?
138
Post  Lem Evans October 18th 2010, 4:45 pm
KY JELLY wrote:That depends on what the m-5 is being burned in Shocked
The combustion chamber Wink
