fuel getting to motor but not starting
fuel getting to motor but not starting Empty fuel getting to motor but not starting
Post  250white460 October 26th 2010, 8:21 pm
i have a 1997 250 with only 67,000 miles on it. i went to pull it in the shop today to change my tires. pulled it in and i went to move it forward some more and it wont start. it cranks fine just like it should but it wont fire. i know its gettin gas cause the pump runs when you turn the key and you can also smell fuel when you get done crankin it. we took the cap off the injector and its shoots fuel out fine. at first there weren't no spark but we tried again and there was. still nothin though. its all stock and im new to the 460 so any help would be real good. thanks
250white460
fuel getting to motor but not starting Empty Re: fuel getting to motor but not starting
Post  chuck stevens October 26th 2010, 9:44 pm
Sounds like you got it flooded, try a new set of spark plugs. Reason: When the unleaded swill they sell as gas today coats the plugs it's almost impossible to dry them off. Being "wet", they short the spark to ground. Alternatively, after you get them out, blow dry them and let them sit for an hour or so...preferably in the sun. Reinstall and as long as you are getting spark you should be good to go. DO NOT PUMP the gas pedal!!! javascript:emoticonp('Cool')
chuck stevens
http://E-MAIL= stevensracingent@aol.com
Post  DanH October 27th 2010, 9:25 am
chuck stevens wrote:Sounds like you got it flooded, try a new set of spark plugs. Reason: When the unleaded swill they sell as gas today coats the plugs it's almost impossible to dry them off. Being "wet", they short the spark to ground. Alternatively, after you get them out, blow dry them and let them sit for an hour or so...preferably in the sun. Reinstall and as long as you are getting spark you should be good to go. DO NOT PUMP the gas pedal!!! javascript:emoticonp('Cool')
you can't flood EFI by pumping the fuel pedal . holding the pedal to the floor helps if flooded . (clear flood mode)
DanH
Post  DanH October 27th 2010, 9:26 am
sorry double post
DanH
Post  chuck stevens October 27th 2010, 12:08 pm
Sorry, I missed that it was EFI. Sad
chuck stevens
Post  250white460 October 27th 2010, 7:39 pm
update: we're getting a spark now but its really weak, any other suggestions. i was told were the center core plug goes to get the spark charge might be bad. sound right? once again anything will help. thanks
250white460
Post  69F100 October 27th 2010, 9:00 pm
Check your coil if the spark is weak I had one on my 69 when hot the spark was weak and wouldn't crank it was like a red spark unstead of a blue spark and also check coil wire it might be bad.the coil is where your spark comes from.hope this helps.
Jim
Post  250white460 October 28th 2010, 6:31 pm
it was the coil haha
250white460
