Largest valve size with C9VE head
Maddmattmustangs
Largest valve size with C9VE head Empty Largest valve size with C9VE head
Post  Maddmattmustangs November 4th 2010, 12:34 am
What's the largest intake I can use with a 1.8 exhaust valve?
Maddmattmustangs
Maddmattmustangs
Largest valve size with C9VE head Empty Re: Largest valve size with C9VE head
Post  dfree383 November 4th 2010, 6:09 am
2.19 is about it. IMO your better off with a 2.25 1.76 combo.
Post  lghting94 November 4th 2010, 8:25 am
Why is that Dave? Can you please explain
lghting94
lghting94
Post  dfree383 November 4th 2010, 8:32 am
with the 1.80 exhaust valve you run out of room and IMO it gets a little tight. A Good rule of thumb is 4" of valve with a stock placement head. 2.25 + 1.76 = 4.01, 1.80 + 2.19 = 3.99
Intake Flow = HP and the exhaust can be compensated for with proper cam timing. You need to get it in before you worry about getting it out.......
Post  rmcomprandy November 4th 2010, 10:25 am
Maddmattmustangs wrote:What's the largest intake I can use with a 1.8 exhaust valve?
In a C8, C9 or D0 head the 2.200" FRPP intake valve #M-6507-B429 seems to work the best in that combination with the 1.800" exhaust valve.
Personally I like the 2.300" intake and 1.710" exhaust valve but, most pistons aren't notched large enough for that intake valve size.
Post  Lem Evans November 4th 2010, 11:03 am
There are still a few M-6507-A429 2.250" valves around.
Post  Maddmattmustangs November 8th 2010, 11:50 am
[quote="rmcomprandy"]
Maddmattmustangs wrote:What's the largest intake I can use with a 1.8 exhaust valve?[/quote
Why do you like that combo though? Better power output up top?
Maddmattmustangs
Maddmattmustangs
Post  rmcomprandy November 8th 2010, 3:11 pm
When you cam for it ... yes. And, if you're talking WOT power, it's better everywhere, not just on the top.
Post  Maddmattmustangs November 8th 2010, 3:18 pm
Do I need to cut the chamber for the 2.3 valve? If not I may just do that then
Maddmattmustangs
Maddmattmustangs
Post  rmcomprandy November 8th 2010, 5:23 pm
Maddmattmustangs wrote:Do I need to cut the chamber for the 2.3 valve? If not I may just do that then
You will probably need to relieve the piston notch if it is not a custom. 2.280" is about all that will fit radially into a normal CJ intake notch.
Post  Maddmattmustangs November 8th 2010, 7:37 pm
I can do that it wouldn't be to big of a deal. Very Happy
Maddmattmustangs
Maddmattmustangs
Post  1Bad91 November 10th 2010, 4:11 pm
2.25 and 1.75 is what I have on my C9 heads.
1Bad91
1Bad91
