A-460 block
A-460 block
I've got a standard head bolt pattern a-460 block how hi can it be bored and stroked safely and how much power can it handle? I'm at 4.5 & 4.5
jason- Posts : 220
Re: A-460 block
4.625b and 4.75s IIRC, but probably more stroke with unobtainium rods and a pile of machine work.
Bernie- Posts : 45
Re: A-460 block
jason wrote:I've got a standard head bolt pattern a-460 block how hi can it be bored and stroked safely and how much power can it handle? I'm at 4.5 & 4.5
Should go 4.600" bore with ease,if I remember correctly, Ford said 4.6250" back in the day, probably could go more with a sonic check. With some clearancing, you can go 4.750" stroke.
Nevs- BBF CONTRIBUTOR
Re: A-460 block
I'm currently running an A460 block with a 4.650" bore and a 4.750" stroke with no problems. A sonic check is a good idea because some blocks experience core shifting in the casting process.
Re: A-460 block
What about the horsepower capability?I've heard dif. Things.
jason- Posts : 220
Re: A-460 block
jason wrote:What about the horsepower capability?I've heard dif. Things.
What are your build plans? I doubt you'll exceed the blocks capabilities...
Re: A-460 block
Twins through a carbNevs wrote:jason wrote:What about the horsepower capability?I've heard dif. Things.
jason- Posts : 220
Re: A-460 block
jason wrote:Twins through a carbNevs wrote:jason wrote:What about the horsepower capability?I've heard dif. Things.
How much boost with the twins? I'd consider an 18 bolt block and heads in a twin turbo application. N/A, I'd run what you have, but that does put a different spin on things with the twins...
Re: A-460 block
twins with pretty much any head you throw on it will make well over 2000hp. That will put you in the mid to low 7's with ease. now if you want to dial it down for say like 7.50's or slower you will not need that much boost and the 10 bolt block will be fine. I personally would use the 18 bolt block but as long as you never plan on running a lot of boost and you are able to keep your tune safe (lots of time with a carb) you will be fine with what ever you want to throw at it.
whatbumper- Posts : 3024
Re: A-460 block
I would be happy with 7.50 to 8.00's like I said the chivy guys here with twin 88s are running 8.70's, and I don't have the cash for an 18 bolt block and heads right now .
jason- Posts : 220
Re: A-460 block
jason wrote:I would be happy with 7.50 to 8.00's like I said the chivy guys here with twin 88s are running 8.70's, and I don't have the cash for an 18 bolt block and heads right now .
Twin 88's on a combo like yours should make around 1200-1300 rwhp at 10-11psi.
Re: A-460 block
Thanks for all the input guys , now I have something to shoot for . One more question if I were to go injection what's a good system without breaking the bank??
jason- Posts : 220
» distributer block hole is too small on an A460 block
» how much is a 1972 429 4bolt cobra jet block worth.. Just the block and main caps.??? std bore
» FACTORY FUEL PUMP ECCENTRICS SMALL BLOCK V BIG BLOCK
» Early style big block { c9v3 heads and block }
» New 57 Ford Project Should we go big block or small block? Pics added
