Anyone been doing any car stuff?
+47
Barney
bcr466
scottke
665 falcon
hillbillyerv
Ranch71460
342g
JT557
Larry T
BigDave65
QtrWarrior
4thHorseman
Tommyj466
valleydawg
95lightiningguy
NO FAIR
jcoxracing
557 mazda
98-9.0Mustang
johndickjr
racnrick
Race Ready Fabrications
512Fairlane
'65 T-BOLT
56Tbird
514Fox87
83-88T-Bird Guy
138
patfromjersey
Larry Williams
bb429power
51 posters
Page 2 of 5 Previous  1, 2, 3, 4, 5  Next
Anyone been doing any car stuff? - Page 2 Empty Re: Anyone been doing any car stuff?
Post  bb429power November 28th 2010, 11:22 pm
racnrick wrote:
bb429power wrote:Is that a truck under all that stuff? Laughing
Very Happy YES, it's a 1950 Dodge Power Wagon, it has been in (under) there since 2001 Exclamation cheers
There's a guy up north with a yellow one of those, maybe its something else though scratch That's not a cluttered garage, my grandpas was though. Shocked Laughing 4 car garage and you couldn't even get in it really, we cleared it out and found a couple engines. BUNCH of airplane stuff since he fixed them for a living in that garage. Cool stuff to find, I got a full micrometer set and a dial indicator too Very Happy
bb429power
bb429power
Post  johndickjr November 28th 2010, 11:25 pm
started on my 80 coupe stang, this will be the last build i will do with my g-pa , he is on his death bed, barely getting around, he had a fast straight 6 back in the early 70's late 1960's, so we are building a cool 306 ci straight 6 ford, ,with 6.79 long rods , (240 rods), fully ported head..,13-1 compression, alum intake, looking for a roller cam for it, i can get a new one for 900.00, pretty nasty 6 banger, it will run high 11 to low 12. range, i am shooting for 12.00 so i can run the local 12.00 index class, these motor make a lot of tq , with a 3.98 stroke
johndickjr
Post  98-9.0Mustang November 28th 2010, 11:35 pm
Yep started my 98 Mustang project. It will be getting a 545 and hope full easy 9s maybe 8s. Stop on over to my build thread and check it out. Its in the proven builds section.
98-9.0Mustang
98-9.0Mustang
Post  bbf-falcon November 28th 2010, 11:47 pm
56Tbird wrote:I'm ass deep in Chuck's car..I ain't got time to work on mine!!Put the tail light panel in it today that i got at the Swap Meet yesterday[img]Anyone been doing any car stuff? - Page 2 Hotrodreunion164[/img][img]Anyone been doing any car stuff? - Page 2 Hotrodreunion165[/img]
Damn Dano, king You don't mess around. You probably had that welded in before I got back home from work today. Good Job Amigo Wink
Anyone been doing any car stuff? - Page 2 Empty albany test n tune 11-28-10
Post  557 mazda November 28th 2010, 11:55 pm
finally got the mazda leaving the line a little straighter got the 60ft time down to 1.15 ran a best time of 5.44 at 126mph letting off. waitin on egt kit to tune carburator should have it down in the low 5's. first full pass with the alcohol
https://s816.photobucket.com/albums/zz86/557mazda/?action=view&current=ricksracecar11-28004.mp4
https://s816.photobucket.com/albums/zz86/557mazda/?action=view&current=ricksracecar11-28003.mp4 affraid
557 mazda
557 mazda
Post  jcoxracing November 29th 2010, 12:51 am
Pulled the rearend of the 67 because I rolled the supposively h.d. moser perches Rolling Eyes , and install a pair from calvert racing. Also pulling the 521 to shave the shock towers, because I am tired of wasting 2 hours to change the plugs.
Justin
jcoxracing
jcoxracing
Post  IDT-572 November 29th 2010, 1:14 am
I will be starting my P-51 headed engine in the next week or so.................... Cool Have everything but the cam, lifters and push rods.
I will also upgrade my glide with a J-W case, 8 clutch drum, and a good 1.80 straight cut planetary gear.
Also, gut the door bars, remove wiper motor and heater controls.
Install after market lightweight front disc break set up.
Add wheelie bar, and parachute.
Maybe bigger tires.................. Rolling Eyes
Got to keep up with the HeRo. You have to use your head and be smart if your going to go fast on gas and a carburetor................ Shocked
Post  NO FAIR November 29th 2010, 1:53 am
Converted the front drums to disc brakes yesterday on the Fairlane.
Dave
Smile
NO FAIR
NO FAIR
Post  95lightiningguy November 29th 2010, 3:16 am
Well been trying to find the motivation to go out and port my second set of heads, will be going over that pretty soon. Mostly buying parts and dealing with setbacks. Gonna go to the local picknpull and get a new short block for the sons truck so he can start on the body work after we get the motor in, figure that will keep him busy till he can drive it legally. Spent the weekend putting struts on all 4 corners of the wifes van and doing an oil change, maybe that will keep her of my back for a while about all my car parts. I feel like some on here with that automotive ADD. Very Happy
95lightiningguy
95lightiningguy
Post  valleydawg November 29th 2010, 8:26 am
Well I finally got the new 598 installed. Ran into every issue you can think of but that is usually the way it goes. Headers are build and installed, extended the travel of my brake pedal and replaced master cylinder, installed a new rack and pinion along with new tie rods. I added a driveshaft enclosure on the car. I also installed a new Stroud Pro Stock chute that will be air launched (nitrous). Been pretty busy the past couple of months on the car.
valleydawg
valleydawg
Post  Tommyj466 November 29th 2010, 12:15 pm
Drained Alky and put gas carb back on race car and parked it. Backed off valves, set on jack stands and moved it to the far bay in the shop. Pulled my son's 66 coupe into the middle bay for work this winter. It's a real piece of work, every panel to be replaced...welded in passenger side front frame rail patch, and front crossmember Friday. Front suspension is being removed,replaced. Have a disc brake set-up to replace the drums on the way. Gonna have to just start at one end and bite off little projects at a time.
TJ
Tommyj466
Tommyj466
Post  4thHorseman November 29th 2010, 12:42 pm
I also managed to roll my stocker spring perches on my 9" and they got replaced with something serious. Braced the rear end while it was out. Pulled the BBF and had it refreshed. Its now a 552ci @ roughly 13:1. Got the headers ceramic coated. Bolting it all back together now. cheers All fresh and pretty... ready to make some power.
Considering converting to alcohol before spring. study
4thHorseman
4thHorseman
Post  jbozzelle November 29th 2010, 5:28 pm
Been slowly gathering parts for the dragster I picked up from Mike. Hope to start cleaning parts and start mocking up the 514 that will go on this week. Hope to have it running before the end of the year. Also been helping a friend swap drivetrains between 2 Mustangs. Both are SBC powered though.
I also plan to find some time to finish the cage on my Mustang as well...
Post  bruno November 30th 2010, 6:16 am
jbozzelle wrote:Been slowly gathering parts for the dragster I picked up from Mike. Hope to start cleaning parts and start mocking up the 514 that will go on this week. Hope to have it running before the end of the year. Also been helping a friend swap drivetrains between 2 Mustangs. Both are SBC powered though.
Shocked Shocked Shocked
http://WWW.CKRME.COM
Post  dfree383 November 30th 2010, 9:09 am
I would like to just be with in a reasonable drive of my car..... so i can do something !!!!!
Post  jbozzelle November 30th 2010, 11:04 am
I've graduated to the big league...
Post  richter69 November 30th 2010, 11:08 am
I wouldnt call a piperack "big league" lol.
Post  Lem Evans November 30th 2010, 11:17 am
You would if was a injected M5 unit Wink
Post  jbozzelle November 30th 2010, 11:18 am
richter69 wrote:I wouldnt call a piperack "big league" lol.
Big enough for me. I was hoping to be the HeRo, but you beat me to it... Laughing
Post  dfree383 November 30th 2010, 11:23 am
There can be only one......... Laughing
Post  richter69 November 30th 2010, 12:02 pm
Lem Evans wrote:You would if was a injected M5 unit Wink
Still needs John Holmes pushrods, green oil (and teeth), stud mount rockers, and gas ports to qualify........ cheers
Post  valleydawg December 30th 2010, 5:42 pm
Here are a couple of things (pics) that I have been working on this winter. I am ready to make some passes now.
Anyone been doing any car stuff? - Page 2 IMG_1435
Anyone been doing any car stuff? - Page 2 IMG_1440[img]
valleydawg
valleydawg
Post  bruno December 30th 2010, 6:00 pm
very , very nice ^^^^^^^^^^^^^^^^^^
Post  bbf-falcon December 30th 2010, 7:51 pm
Very nice Dawg. Shocked Cool
Post  jbozzelle December 30th 2010, 9:05 pm
I cleaned and painted my block today. Also got the pistons and pins cleaned. Filed the rings earlier this week. Tomorrow I'll clean the crank, bearings and rods and start the assembly process. Hope to have it in the dragster some time next week.
