8.50 or 7.50 Certified cage pictures in Fox
8.50 or 7.50 Certified cage pictures in Fox Empty 8.50 or 7.50 Certified cage pictures in Fox
Post  studly December 6th 2010, 4:11 pm
Anybody got any pictures or digrams of what a properly laid out roll cage for 8.50 or 7.50 certified should look like.
studly
studly
8.50 or 7.50 Certified cage pictures in Fox Empty Re: 8.50 or 7.50 Certified cage pictures in Fox
Post  bruno December 6th 2010, 4:20 pm
a cheap investment would be an sfi book
http://WWW.CKRME.COM
Post  jones December 6th 2010, 4:50 pm
Big differance between a 8.5 and 7.50 cage, 8.50 is your basic 10 point cage, 7.50 is SFI. You really need the SFI book to see all the bars under the car.
jones
Post  DILLIGASDAVE December 6th 2010, 10:35 pm
Going with the SFI specs even if you never plan on going that fast can add to the future resale value of a car when/if you ever decide to sell it.
Post  studly December 6th 2010, 11:08 pm
I have a legal 10 point cage by this
http://www.nhraonline.com/contacts/tech_faq.html
just thinking about adding the funny car cage and 12 point bars to the front i guess i will order the book and see what has to be done
studly
studly
Post  DILLIGASDAVE December 6th 2010, 11:35 pm
If your looking for an SFI book, & your car is a "back-half" car or a "mini-tub/stock suspension" car, you will probably need the 25.5 SFI spec book since it deals with cars that have stock/modified floor and firewall with OEM frame and/or uni-body construction.
Post  whatbumper December 6th 2010, 11:43 pm
DILLIGASDAVE wrote:If your looking for an SFI book, & your car is a "back-half" car or a "mini-tub/stock suspension" car, you will probably need the 25.5 SFI spec book since it deals with cars that have stock/modified floor and firewall with OEM frame and/or uni-body construction.
agreed. very easy to understand too.
Post  studly December 7th 2010, 1:00 am
car is stock suspension no mini tubs and untoched floorplans as of yet, I have weld in sub frame connectors, but was thinking of adding threw the floor subframs while interior is out and upgrading cage over the winter, car is getting to fast without trying to upgrade cage. I do have the normal upgrades, upper and lower controll arm reinforcement, anti roll bar and solid bushings with all upr bolt in suspension parts and qa1 double adjustable shocks bolt in. but the floorpan has never been cut just reinforced with plates above the upper control arm mounts and lower controll arm mounts in rear.
studly
studly
Post  whatbumper December 7th 2010, 9:53 am
after you do the through floor subframes there really isn't much more to do with the floor with what you described you have. spend the $20something dollars for the SFI 25.5 book.
