Motor has No spark?
+14
bigblok2000ranger
DFI429
lghting94
The Pope
bcr466
BigDave65
KY JELLY
bb429power
Filucky
1Bad91
18 posters
Page 1 of 3 1, 2, 3  Next
Motor has No spark? Empty Motor has No spark?
Post  1Bad91 December 12th 2010, 12:47 pm
Well, I've tried a few things to see what the problem is. I first thought it might be the pick-up. Changed that, nothing. Then I tried another coil, still nothing. SO then I tried to test the Box, used a jump wire and I'm getting spark off the Coil wire to the Distributor. What else could it be?? MSD instructions stated if you get spark, then the coil is bad and the box is good. But I tried another coil in which I knew worked, so I'm puzzled at this point. Any help here??
1Bad91
1Bad91
Motor has No spark? Empty Re: Motor has No spark?
Post  Filucky December 12th 2010, 1:17 pm
I had spark problems before with a MSD setup, it still had some spark but misfired and ran like crap. I tried everything from a dizzy swap, coil and MSD box swap but it turned out to be my tach was junk, so you might want to look into stuff you have hooked up to your MSD like N2o timers, timing box's ect. Good luck.
Filucky
Filucky
Post  bb429power December 12th 2010, 4:21 pm
Make sure your crimps are good too, sounds dumb but I've had problems with my msd box and the company said part of the problem were the crimps. Rolling Eyes Crimps appeared fine though, just check it over and make sure its all good. Could just be something basic that you wouldn't even think about, usually is for me anyway. Laughing
bb429power
bb429power
Post  bbf-falcon December 12th 2010, 4:41 pm
Get another plug that you know is good and attach one of your plug wires to it and grd.to engine.Whirl it over and see if it fires the plug.
Post  1Bad91 December 12th 2010, 5:22 pm
bbf-falcon wrote:Get another plug that you know is good and attach one of your plug wires to it and grd.to engine.Whirl it over and see if it fires the plug.
I also tried this too. Still no luck. I just dont want to spend $1000 on new things I didn't even need...lol. The box appears to NOT be the problem though....any other ideas guys?? I have a potential race on the 1st and don't wanna be holding the bag still.. scratch
1Bad91
1Bad91
Post  KY JELLY December 12th 2010, 5:32 pm
I am guessing you have checked to see the distributor is turning ? No reluctor paddles broke ?
KY JELLY
KY JELLY
Post  1Bad91 December 12th 2010, 5:34 pm
KY JELLY wrote:I am guessing you have checked to see the distributor is turning ? No reluctor paddles broke ?
Distributor is turning.....reluctor paddles?? Your referring to the fins on the shaft?
1Bad91
1Bad91
Post  Filucky December 12th 2010, 5:53 pm
Do you have anything hooked to the MSD box other then the coil, dizzy and tach? If so try unhooking it all and just run the basic box setup without the tach or rev limiter chip pluged in. Start with the basics and then add on one piece at a time untill you find whats not working.
Filucky
Filucky
Post  1Bad91 December 12th 2010, 6:18 pm
Filucky wrote:Do you have anything hooked to the MSD box other then the coil, dizzy and tach? If so try unhooking it all and just run the basic box setup without the tach or rev limiter chip pluged in. Start with the basics and then add on one piece at a time untill you find whats not working.
hmmmm, now I can work with that man. I will try that
1Bad91
1Bad91
Post  BigDave65 December 12th 2010, 6:27 pm
Make sure you have 12v going into the MSD and a good ground.
BigDave65
BigDave65
Post  Curt December 12th 2010, 6:47 pm
BigDave65 wrote:Make sure you have 12v going into the MSD and a good ground.
Yeah, 12v straight to the battery, and ground straight to the battery.
Post  KY JELLY December 13th 2010, 9:26 am
Yes that's what I am referring to. I would go with what Filucky said , have any oil pressure 02 or egt safety shut off's , etc. Only other thing it could be is a loose connection to the ignition switch / box or coil.
KY JELLY
KY JELLY
Post  bcr466 December 13th 2010, 9:36 am
You say there is spark from coil wire AT dist but no spark at plugs? Rotor is bad. If I am understanding what you described symptoms.
bcr466
bcr466
http://cracing@frontiernet.net
Post  1Bad91 December 13th 2010, 5:07 pm
theres spark from the coil wire, but none from dist wire when connected...I have replaced the cap, button, pick-up (all new only 2 months old)
1Bad91
1Bad91
Post  bb429power December 13th 2010, 8:07 pm
Did the problem start right after you put something on it? I have yet to deal with a bad rotor but, if spark's going in but not coming out...Got to be something right there in the distributor.
bb429power
bb429power
Post  1Bad91 December 13th 2010, 8:36 pm
bb429power wrote:Did the problem start right after you put something on it? I have yet to deal with a bad rotor but, if spark's going in but not coming out...Got to be something right there in the distributor.
Yes I did change the set-up. I went and locked the timing out and put it back on the car and then the problems started then.
1Bad91
1Bad91
Post  richter69 December 13th 2010, 8:41 pm
somthin in the dizzy.............
Post  1Bad91 December 13th 2010, 9:09 pm
I tried testing the box again with the jump wire, and the red-light on the Digital 6 Box went out but the ignition switch was still on and the ignition light was still on. No blown fuses of any kind. Also, I unplugged the Tach wire that went into the box too. Not sure if this has anything to do with it. The light on the box was on when I turned the ignition on. You guys think it would either be the Box or the coil?? Gonna figure this out but def puzzled at this point. Never had any kind of problem like this before till I took the Dizzy out and tried locking the timing out.
1Bad91
1Bad91
Post  richter69 December 13th 2010, 9:15 pm
so I understand you get spark from the coil wire but none from the wire that goes to the plug correct?
Post  1Bad91 December 13th 2010, 9:18 pm
richter69 wrote:so I understand you get spark from the coil wire but none from the wire that goes to the plug correct?
Correct. When everything is plugged back in and 1 plug wire is taken out of a cylinder....No spark. Would this mean the coil is bad??
1Bad91
1Bad91
Post  1Bad91 December 13th 2010, 9:19 pm
I only get spark from coil wire when I test the box. Using the jump wire
1Bad91
1Bad91
Post  richter69 December 13th 2010, 9:40 pm
sounds like the pick up in the dizzy got messed up somehow.........this a msd unit where you have to pull the shaft out to lock it in?
Post  bb429power December 13th 2010, 9:47 pm
richter69 wrote:sounds like the pick up in the dizzy got messed up somehow.........this a msd unit where you have to pull the shaft out to lock it in?
Could the gap be way off between the reluctors and the pickup?
bb429power
bb429power
Post  1Bad91 December 13th 2010, 9:50 pm
Exactly. I tried my other coil again just to try again and motor back fired. Tried again and still no spark.
1Bad91
1Bad91
Post  bb429power December 13th 2010, 9:52 pm
Pull the cap off and check the air gap between the pick up and reluctor. Would only take a second and would be easy to just say "that ain't it."
bb429power
bb429power
