480 BUILD hp?
480 BUILD hp? Empty 480 BUILD hp?
Post  71torino December 12th 2010, 7:02 pm
Let me know what you think. 480 stroker,motorsport cj heads (ported),motorsort intake (ported to heads). Dont have any flow numbers for heads. Should be around 11:1, voodoo solid roller,261-267 605-640. 2 inch headers-3 1/2 collectors. Dommy carb (looking for one). Goin in a 71 torino hardtop,weigh's 3550 with me in it with a cleveland. c6 3500 stall,full manual vb. 4:11 gears. What kind of HP? Guess on what it would run?
Jesse
71torino
71torino
480 BUILD hp? Empty Re: 480 BUILD hp?
Post  The Mad Porter December 12th 2010, 7:46 pm
71torino wrote:Let me know what you think. 480 stroker,motorsport cj heads (ported),motorsort intake (ported to heads). Dont have any flow numbers for heads. Should be around 11:1, voodoo solid roller,261-267 605-640. 2 inch headers-3 1/2 collectors. Dommy carb (looking for one). Goin in a 71 torino hardtop,weigh's 3550 with me in it with a cleveland. c6 3500 stall,full manual vb. 4:11 gears. What kind of HP? Guess on what it would run?
Jesse
Given a good flowing set of heads and a well sorted out combo...
640 to 670 HP with a 1050 dommy.
Low to mid 11's at 3,750 racing weight. You might need more stall.
Very Happy
The Mad Porter
The Mad Porter
Post  71torino December 12th 2010, 9:24 pm
I have a 4000,I will just use it then. Running a 28.11/50 15 hoosier slick. Car hooks very hard and works very well. Car also has a 150 shot in it now.
71torino
71torino
Post  whatbumper December 12th 2010, 11:15 pm
71torino wrote:I have a 4000,I will just use it then. Running a 28.11/50 15 hoosier slick. Car hooks very hard and works very well. Car also has a 150 shot in it now.
you mentioned two converters. one 3500 and the other 4000, what motor/power levels are they rated for? another words those numbers can change easily.
Post  71torino December 13th 2010, 8:23 am
The 4000 was built for a bbf stroker,the 3500 what from a stroker cleveland.
71torino
71torino
Post  whatbumper December 13th 2010, 9:49 am
71torino wrote:The 4000 was built for a bbf stroker,the 3500 what from a stroker cleveland.
Just making sure you understand that they will be different behind different motors.
